Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-31-2009, 02:47 PM   #1
lp2004z06
Junior Member
lp2004z06's Avatar
Default Does all Gas have 10% Ethanol?
Just saw a post where a guy from IN said there is a Shell gas station in his area that doesn't have the 10% Ethanol. Is there anywhere in Eastern PA or Central Jersey that you can get gas without the Ethanol? I thought it was mandatory to have ethanol in the fuel. Am I wrong?
lp2004z06 is offline   Reply With Quote
Old 12-31-2009, 03:18 PM   #2
jbondfl
CF Senior Member
St. Jude Donor '12
Support Corvetteforum!
jbondfl's Avatar
Location: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
Can't really ever say ALL without being wrong.
Most gas has up to 10% ethanol. It's an emissions thing. Ethanol is used in place of PTFE taht was used but is highly toxic and leached into the ground from tanks.
If you really must have ethanol free ( and honestly 10% isn't going to hurt anything on your car) you could try marine fuel. I think most of that is still ethanol free.
jbondfl is offline   Reply With Quote
Old 12-31-2009, 03:48 PM   #3
stingraymyway
CF Senior Member
St. Jude Donor '09-'10-'11-'12-'13
stingraymyway's Avatar
Location: Out of Site...Out of Mind. Corvette: anything else is just transportation.
Not all gas does. There's a couple of stations in my area that have signs up stating "no ethanol". The cost is a little more per gallon, go figure......., I hope they're being honest.
stingraymyway is offline   Reply With Quote
Old 12-31-2009, 04:05 PM   #4
Blu Angel
CF Senior Member
Blu Angel's Avatar
In Canada at my local Shell retailer
regular gasoline......10 % ethanal
mid-grade gas..........5 % ethanol
premium gas...........0 % ethanol
Blu Angel is offline   Reply With Quote
Old 12-31-2009, 04:05 PM   #5
GrandpasC502
CF Senior Member
St. Jude Donor '12
GrandpasC502's Avatar
Location: If opportunity doesn't knock, build a door. Georgia / Michigan
Convenience stores around marina's with a boat launch is your best chance for 100% gasoline. A lot of their business is marine since they are typically cheaper than the marina. Boats are also a high ticket ring for them since the larger tow-able boats have relatively large tanks.
GrandpasC502 is offline   Reply With Quote
Old 12-31-2009, 05:04 PM   #6
peter pan
Life Time NCM #2196
peter pan's Avatar
Pretty much all the stations around the San Antonio area do, atleast where I fill upClick the image to open in full size.
peter pan is offline   Reply With Quote
Old 12-31-2009, 05:22 PM   #7
SugarDemon
CF Senior Member
SugarDemon's Avatar
Plenty of stations around OKC without ethanol. Even the Murphy's Oil (Wal Mart) here has non-ethanol.....at least until it goes up to 4 bucks again.
SugarDemon is offline   Reply With Quote
Old 12-31-2009, 05:25 PM   #8
'99 SLP#24
CF Senior Member
'99 SLP#24's Avatar
Yeah there are quite a few stations in OKC that run no ethanol. Oklahoma made it a state law a few years ago that it must be posted on the pump if the station is putting blending ethanol in.
'99 SLP#24 is offline   Reply With Quote
Old 12-31-2009, 05:31 PM   #9
dominic9
CF Senior Member
dominic9's Avatar
Send a message via AIM to dominic9
All land and marine gasoline in NJ is E10. Only aviation fuel is E-Free.
dominic9 is offline   Reply With Quote
Old 12-31-2009, 06:08 PM   #10
Mr.Bill
We Miss You Frank Z.
St. Jude Donor '12-'13
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
Send a message via ICQ to Mr.Bill
Here in Reno you will find 10% from November till March, A winter thing.
Mr.Bill is offline   Reply With Quote
Old 12-31-2009, 06:25 PM   #11
itzza427
CF Senior Member
itzza427's Avatar
I believe pretty much all Illinois and Missouri is 10%E. I know for a fact for at leas a couple hundred mile radius from St.Louis is. From what I have read the state of Illinois is actively promoting ethanol use!!
itzza427 is offline   Reply With Quote
Old 12-31-2009, 06:35 PM   #12
jrose7004
CF Senior Member
jrose7004's Avatar
Quote:
jrose7004 is offline   Reply With Quote
Old 01-01-2010, 02:17 AM   #13
prseasix
CF Senior Member
prseasix's Avatar
Location: NW Fla - Take it easy on 06ama- it's his first job!
Around here in NW FL, that's all I seem to recall seeing.
prseasix is offline   Reply With Quote
Old 01-01-2010, 07:01 AM   #14
tstar
CF Senior Member
St. Jude Donor '11-'12
tstar's Avatar
Kwik-Fill has no Ethanol and is made from USA crude in the US;
http://www.kwikfill.com/home/home.php
__________________
Tim
Pewter 99 Coupe MN6
tstar is offline   Reply With Quote
Old 01-01-2010, 11:37 AM   #15
rws.1
CF Senior Member
rws.1's Avatar
I thought the EPA ruled all gasoline had to contain 10% ethanol about 2 years ago....
Guess I need to do some research...
rws.1 is offline   Reply With Quote
Old 01-01-2010, 11:58 AM   #16
waunavet
CF Senior Member
waunavet's Avatar
In WI, some Shell stations have hi-test (91) that is 100% gasoline. As mentioned above, marinas usually have no ethanol premium because of the problems older boats can have buring corn gas.
waunavet is offline   Reply With Quote
Old 01-01-2010, 11:59 AM   #17
waunavet
CF Senior Member
waunavet's Avatar
Still a states rights issue.
Old 01-01-2010, 12:58 PM   #18
SugarDemon
CF Senior Member
SugarDemon's Avatar
I think the federal government has a mandate targeting ethanol capacity that must be introduced into the national fuel supply. So many billions of gallons must be produced and the mandate increases every few years. Unfortunately, everyone jumped into the ethanol production business at once and a huge amount of overcapacity developed. It seemed like a no brainer as the federal mandate, the tax credits, and increasing demand due to high oil prices made it very appealing.
I worked a bunch of ethanol plant loans in NYC last spring (including this one) and you couldn't hardly give those plants away.
http://www.mysanantonio.com/business...ol_plants.html
Old 01-01-2010, 01:03 PM   #19
waunavet
CF Senior Member
waunavet's Avatar
Several in WI have gone under partially due to lower commodity prices.
Old 01-01-2010, 01:40 PM   #20
TR Vert
CF Senior Member
TR Vert's Avatar
That is a learning for me.... I thought all gas was the same.
TR Vert is offline   Reply With Quote
Reload this Page Does all Gas have 10% Ethanol?
Tags
0, 10, 1015, california, chevron, ethanol, federal, fuel, garland, gas, gasoline, kwikfill, law, marina, require, shell, tx, walmart
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 87 12-02-2012 10:57 AM
Some interesting information curvesman C6 Z06 Discussion 25 08-22-2005 08:53 PM
Fuel additive recommendations for '64 Beck1 C1 & C2 Corvettes 16 07-29-2005 04:22 PM
Delphi 32 / 37lb Disc Injectors Racetronix C5 Parts for Sale/Wanted 30 06-16-2005 11:45 PM
what grade gas do you use ??? speee C4 General Discussion 41 05-16-2004 01:49 AM
Hel!! Lingenfelter SC with DTC codes 1120 or 1221 Rhino21149 C5 Forced Induction/Nitrous 13 03-03-2003 08:44 AM
10% ethanol effect on performance fifimonster C5 Tech 11 05-24-2002 11:35 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
