Key Fob Range
Key Fob Range
What range are you guys getting from your key fobs? It seems like I have to be between 5-10 feet for mine to work. I know I've seen others have a lot longer ranges.. any idea why mine is bad? Do I need a new fob?
Straight line, over 75 feet. 5 to 10 is weak. Do you just have the one? Definitely try the battery first.
From the 2000 manaul:
Operational range varies with the orientation of the transmitter. For best performance, hold the transmitter vertically, with the buttons facing you and the bottom cover of the transmitter towards the vehicle. As battery life decreases, so does the maximum operational range of the RFA transmitter. In most cases, the transmitter battery should only be replaced when the operational range has severely decreased. If the transmitter range decreases or the transmitter does not operate, test for the following conditions:
Says range is 50 to 100 feet. With the most range from the side and back of the car.
Received 19,439 Likes
'20-'21-'22-'23-'24
You should be able to get at least 50 feet of range with a properly working fob. Might want to check the battery like was mentioned above.
Change the battery. It should be a type CR2032. I had a similar problem before, but after I changed the battery, the range went way up. Problem solved.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
I don't know the range, mine have fresh batteries and I usually hit the button about 10 feet from the car ?
Veteran
Received 1,680 Likes
Some days the range is farther than other days.
USMC (retired)
Do I need to do anything after installing a new battery or I just go and replace the battery and move on?
I am having distance problems as well, therefore I ask.
