[Z06] Occassional grind in 1st
Situation: when I'm stopped, I shift into first, throttle and slowly let the clutch out.
Sometimes, maybe 1-8 times, I will hear a grind right underneath the shifter and the car will not go forward.
It only happens in first. If I'm on a decline and start out in second, it doesn't happen.
Other than the issue from 1st, every shift is fine all the way from 2nd to 6th. Shifting into R is fine as well.
Any ideas or suggestions on what the issue is?
People, PLEASE stop recommending the "ranger" method for every single clutch/transmission related problem that comes up on the forums. Maintaining your clutch fluid (which, btw would not even have to be done on the scale that Corvette owners endure if GM had engineered a good clutch system) is only a band aid solution. There are many mechanical parts in the transmission and clutch system that can go bad, and keeping your clutch fluid clean regularly only keeps any developing problems at bay for that much longer.
Lots of people's problems have been solved using that method. It does sound like there are bigger problems, but it's a good place to start. The bottom line is GM engineered something that does need band aid fixing every now and then. To say that using that protocol to prolong a problem is a bad idea is an ignorant statement in my opinion... that's the whole idea of regular maintenance. why would you even want to keep dirty fluid in your system? wow.
Case in point - My own experience. I regularly maintain everything on my car. For the past 20k miles (ever since I owned my z06) the clutch fluid has never seen the slightest amount of dirt. I literally changed it every week to every 2 weeks or so. Guess what? Not only did my transmission become hard to shift into first, it has now developed a serious grinding if I try shifting into first.
Keeping your clutch fluid clean should be part of regular maintenance. In my opinion, it is not a solution once other problems become apparent.
This happens to me occasionally, and is is easy to fix. The noise you hear is the trans jumping out of gear, and as already pointed out, can really be startling.
There is apparently no discussion in the owners manual, but in my older ZR1 manual ( with the terrific ZF trans), the discussion was to the effect that the gears in that specific transmission were cut differently, and sometimes were hard to put fully into gear at a full stop. The solution is to let the clutch out momentarily in neutral to spin up the gears and the first gear will fully engage. That will solve the problem 100% if the trans is not damaged. And you don't need to do it every time, just when the shift into first 'feels wrong". For me, once or twice a day, usually when stopped for some time at a light, or if i don't shift immediately upon stopping.
In the ZR1, the reason for the different cut on the gears was for added strength. I would not be surprised if the ZO6 had a similar issue, but the issue, to some degree or other, can relate to any manual transmission.
Hope this is helpful............
That's what it feels like at times.
What I did today was try something different. Shifting into 2nd is much easier than shifting into 1st. So what I did at the light was shift into second and then shift up into 1st before I took off. Haven't had an issue with it since.
If it makes any difference:
Trans fluid is Amsoil Universal ATF
Gear fluid is Amsoil GL-4 75w-90
I just put it in last weekend.
It was cold here this morning so shifting was a little more work, I expect that though because it's the same way in my '08 tC with the 5 speed.
Coming back from base, I drove the car harder. Still shifts damn smooth all the way to 6th when I run the car harder. Don't know why...
Can I damage the trans by starting in 2nd?
I use 2nd gear about 80% of the time starting off in mine. I too am running Amsoil in the rear and in the trans.
I have (had) about 2k miles, maybe less on the Amsoil fluid. Once I got the 1rst gear grind it happened quite a few times before I just gave up and started putting the shifter into 2nd prior to engaging 1rst.
Last night I dumped the Amsoil fluid out. Looked at it for shavings and found nothing. Then I went through the fluid with a magnet. Still no shavings. I replaced the Amsoil with Penzoil ATF. We'll see if there is any difference with this 1rst gear grind after a couple hundred miles, but I'm not keeping my fingers crossed.
Do you get any grinding with 1rst gear?
I do not get any grinding going into any gear but sometimes it is harder to get it in 1st completely if I am not paying attention. I have to be completely stopped and may have to let out on the clutch or roll the car to get it completely in gear. I never try to force it into gear. Changing the fluid is easy enough to do I have entertained changing it once a year even though I know it does not need it.
Regards,
But in any case, these are minor issues to the people for whom these cars are meant to be sold to, because adding large performance potential to an existing design always has trade offs (another example is the different suspension geometry in the ZO6). What I was suggesting, based on what I had known previously, is that one should not be too concerned about this. it is "the nature of the beast". And obviously, what I have been describing is not the entire story. I am sure that if one of the 6 speed transmission designers got on here, he could add much more detail.
I will look for some of the ZR-1 stuff. I think it is still around.
