What is the rpm at idle?
Hi There;
Its computer controlled, no adjustment.If you have a cam & a CAI its going to be self adjusted by the computer to about 1000 rpm about 750 to 900 on a stock engine.
robsc501
robsc501
Stock should be near 750-700. run some injector cleaner with the next tank o gas and see if that helps.
Received 19,571 Likes
'20-'21-'22-'23-'24
My '03 idles at about 750 rpm.
I think my custom HPtune is set to low at 500. When the car is hot it`s ok but on a hot day if you turn the AC on and the motor is cold it tends to kill the engine. So what I`m supposed to do, drive all the way back to RPM Motors to have Charlie re-set the RPM?
Need to go anyways, he left me stuck with a locked Diablo Predator, 359.00 plus 75.00 in twice sold twice returned shipping, leaves for a very bad bad taste in my mouth. My RPM Motors HP tune ended up costing me 500. plus the 430.00 or so. So over 900.00, WTF!
Other than that complaint, a FLAWLESS tune
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
