[Z06] !!! im ANGRY .. DAMMMIT!!! once again!!
Well about 12 months ago I had the service column lock repair done on my car, they sayd that they installed a harnest kit on it. Well today all of a sudden I get the service column lock message again but the thing is my steering column unlocks and the car starts but it shuts off when I go past 2mph. So now the vette is at the dealership. I'm waiting on a call to see what they found wrong with it and what caused it if the damm column lock doesn't even lock just the message comes out and the car shuts off after 2mph. What should I expect to be the problemm, anyone ever have this happend to them? Any price range of what to expect to cough up to them? I have a 2001 z06. Thanks guys for the imput
I would be angry too. Sounds like a faulty harness...not uncommon from my research I went through months back. You should probably just get the CLB module like I did and be done with it. I also had my tuner set the max speed to 199 before fuel shutoff just to make sure that if the gremlin ever shows up again, he is overridden.
Yeah.. I hope the dealer just has to reset the pcm or something and it won't be an expensive fix . And I will defenetly get the clb module installed and get a tuner to set the max speed shutoff to 199 but I have a few ? If I install the clb will the servise lock message still come off, if so with the clb how will I remove the message. And is the max speed shutoff setting only designed for the column lock problem?
Well fellow forum members please keep the reply's comming. I want as much input of this problem as I can get. I'm already stressed because animal control is making me pay all these fees for my 2 dogs and well I'm just compleatelly out of it rightnow with all these problems happening to me. Well I'm off to bed. TTYL
The CLB does not solve the problem. I've had the kit from CofH from day 1 in my '03. I've had the Z shutdown and give me the same message 3 times in the 6 years I've owned the car. Each time I've waited 10 seconds and the car starts right up after that. Keeping my fingers crossed...
My car had the K-harness and starting doing the exact same thing you are describing. I bought the aftermarket harness and replaced the K-harness...problem solved.
I later had the car reprogramed and they turned off the fuel shut off after 2mph in case the problem ever comes back up.
Haven't had a problem since...that was a year ago.
Dammmittttt... the dealer just told me that the " column lock actuator was not working". So it was sending the bcm the error causing the service column lock and making my car shut off at 2mph. Damm the whole fix was a damm $687.00 .
had a CLB in my 99 for 8 years and in the 02 for 2 years and not once has the issue ever came back nor have we had a car shutoff.....
is this a Z06 issue???
and $687??? I would tell them to get F'd...THEY SUPPOSEDLY fixed it....now they can fix it for FREE
Well I save all my reciepts from the work I get done on my vette and I showed them the ticket from when they installed the k harness on under the warranty. They told me that the lock actuator was not covered under the gm warranty so I had to pay for it.
Good luck.
The shut down is the factory "fix" installed for the CL issue. The CLB will keep the column from locking, however if you have the ECU flashed with the fix, I can see how it'd still shut down, even though the column doesn't lock (with the CLB in place).
Get the flash *fix* out of there with a custom tune, use the CLB from Corvettes of Houston, and you shouldn't have any further problems.
I don't blame you for being PO'd.
I guess I don't know how GM's "fix" works, but the CLB completely eliminates the actuator from the circuit. So, if you have a CLB installed, a bad actuator will not cause any effect.
