Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-27-2009, 07:42 PM   #1
Michael99Vette
CF Member
Default Performance increase
Here's some performance upgrades I've done and some numbers from a Dyno.
I installed the Vararam intake with the Power Duct. I had my car set up on a Dyno and tuned. Along with these changes I also had the 2.73 diff swapped out for a 3.73 diff (DTE).
Let me say, before I give you my numbers... these changes have really livened up my car. It's a thrill to drive now. I was pretty disappointed with the performance when I first got it.
Rear wheel HP = 305.32
Rear wheel TQ = 304.97
How does this sound for the changes I've done so far?
I'm still not real happy with the holeshot. It'll spin the tires now as before it wouldn't even chirp the tires. But it's still a little sluggish coming out of the hole. I know this car is way more powerful than the 85 Vette I had, but that 85 would light the tires up when I smashed the gas. I mean they would fry! No power braking needed. It was a riot to drive.
Let me know what you think.
Michael99Vette is offline   Reply With Quote
Old 10-27-2009, 07:53 PM   #2
2k2C5
CF Senior Member
Support Corvetteforum!
2k2C5's Avatar
Not bad for what was done. Bare in mind that the Vararam won't show much of a gain on a Dyno. It performs best on the road at higher speeds, not on a dyno with a fan blowing.
As for breaking the tires loose from a dead start. Have you tried it with the traction control off? I would suggest Competitive Mode as this will disable Traction Control but leave Active Handling on. If you have a 99 Active Handling was an option that year so you may not have it and therefore wouldn't have Competitive Mode.
2k2C5 is offline   Reply With Quote
Old 10-27-2009, 08:07 PM   #3
Indy
CF Senior Member
Indy's Avatar
You should easily be able to spin the tires without traction control, even without any mods...the gears will make the most difference in acceleration in your case...intake and tune make more hp, but you won't feel a huge difference...but going to 3.73 will be a whole new driving experience.
__________________
V I P E R rt/10 GenII / silver
H U M M E R H2 / yellow / lifted / 37" STT
Plymouth P R O W L E R / red - sold
Corvette C5 / Millennium Yellow / 6M - sold
Corvette C5 / Nassau Blue / 6M - sold
J E E P ZJ / 7" lift / white / 35" Cooper STT - sold
J E E P TJ / 7" lift /chillipepper red / 37" MTR - sold
Mustang GT 4.6 / black / 5M - sold
"Give Quiche a Chance"
Indy is offline   Reply With Quote
Old 10-27-2009, 08:22 PM   #4
bryanthomas
CF Member
2.73 to a 3.73 and the off the line power still disappoints? Sounds like you need to get a new stall converter. I would recommend either a Yank or Precision Industries. With those 3.73s and a 2800-3000 rpm stall converter you'd likely shave .5 seconds off your 1/4 time. Not sure if you drag race, but that kind of give you an idea of what a difference those mods make on an auto.
bryanthomas is offline   Reply With Quote
Old 10-27-2009, 08:42 PM   #5
moserbe
CF Senior Member
moserbe's Avatar
Turn the traction control off and hold on to the steering wheel. My C4 will burn off the tires too but the C5 is an animal when you disable the anti-wheel spin system.
moserbe is offline   Reply With Quote
Old 10-27-2009, 08:55 PM   #6
andrewdonald1
CF Senior Member
andrewdonald1's Avatar
Screw it... I say throw a supercharger on it.....
At least that is my dream... maybe fantasy...
andrewdonald1 is offline   Reply With Quote
Old 10-27-2009, 10:03 PM   #7
tlc0706
CF Senior Member
tlc0706's Avatar
Curious what happened with the TC off....
tlc0706 is offline   Reply With Quote
Old 10-27-2009, 11:50 PM   #8
RedRiderZR1
CF Senior Member
RedRiderZR1's Avatar
Quote:
That's what I did. Now I can't seem to get any traction.
Another reason why you might not be able to fry the tires is Torque Management on your C5 auto trans. Disable that and then you should be able too. With a 3.73 diff, I would think you should be able to with traction control turned off. If not, take to a shop and have a tune done and have them turn off the Torque Management as well.
Then you should be able to make the tire companies happy.
RedRiderZR1 is offline   Reply With Quote
Old 10-28-2009, 08:35 AM   #9
Michael99Vette
CF Member
I don't drive with the traction control on. That's one of the first things I do is take that off ( a single button on the console). The torque management control is off. DTE turned that off when they installed the 3.73 gears, and Vettesport comfirmed the torque management was off when he performed the tune on the dyno. I thought about a new stall converter, but I've been told by enough people that I should be able to fry the tires now, I thought I should find out why I'm not, before I add more parts.
Old 10-28-2009, 09:44 AM   #10
andrewdonald1
CF Senior Member
what kind of tires are on it?
Old 10-28-2009, 10:11 AM   #11
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
Not bad numbers now, but what were the original hp and torque numbers? With the new rear gears, you should feel a heck of a difference in take off.
Vetteman Jack is online now   Reply With Quote
Old 10-28-2009, 10:27 AM   #12
Todd157k
CF Senior Member
Todd157k's Avatar
The difference you feel is from the rear end change, not the intake. You should either put headers/cam on it, or just go FI.
FI goes from "excitement" to "down-right scary" real quick.
__________________
2004 Black Z06 P1SC1, 60# inj, BBK shorties. 525rwhp/460rwtq w/meth.
---"Black" it's not just a color... it's a career.
2014 Mercedes CLA250
2012 Ram Laramie Longhorn
2006 GoldWing
1967 Triumph Bonnie
1994 Monterey 225 boat
(ok, so I like toys..)
Todd157k is offline   Reply With Quote
Old 10-28-2009, 11:47 AM   #13
rboineau
CF Senior Member
Unless you are running super high-traction tires, your car with the 3.73 should spin the tires into next week. Something is wrong. . . .
rboineau is offline   Reply With Quote
Old 10-28-2009, 11:55 AM   #14
blacksedan87
CF Senior Member
blacksedan87's Avatar
Location: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and we're wearing sunglasses......HIT IT!"
I am a believer in the following:
1. Better breathing (intake improvement) requires better exhaust. If you can take more air in - you need to be able to get more air out. That means long tube headers, high flow cats and a cat-back exhaust.
2. Improved intake and exhaust requires a tune from a professional tuner to take advantage of the improvements.
With intake, headers, cats and a tune - you should expect something in the area of 35 rwhp gain, that plus your gear swap, you should be able to absolutely melt the tires.
Personally - I like the Kooks system with their high flow catted x-pipe.
blacksedan87 is offline   Reply With Quote
Old 10-28-2009, 12:10 PM   #15
blkvette98
CF Senior Member
Default Performance
I have the same mods as you but a couple in addition. Chuck C.O.W. talked me into a 2600 stall and later on he put a set of AR long tubes. You can lite the tires at will. I really like his work! Car really performs well. Its so much fun but Its hard to keep your foot out of it! Give him a call. I'm sure he'll get you pointed in the right direction.
blkvette98 is offline   Reply With Quote
Old 10-28-2009, 03:35 PM   #16
Michael99Vette
CF Member
The tires are Michelin ZP Pilot Sport A/S zero pressure 245/45 zr17 95y.
They were on it when I bought. And they're pretty new.
I just went outside and warmed up my car. In my driveway... I left TC on and nailed it. It started out not really frying the tires but spinning just enough to leave marks on the pavement and it felt a little doggy. A second or two. As the RPM's built it started to cut loose more.
Now... with TC off. Almost the same thing. At initial takeoff the tires were barely spinning. Just enough to leave marks and it felt doggy. Just like with TC on. The difference though, once the RPM's built the tires really cut loose and I left a cloud of tire smoke. But, I'll guess that
started to happen about 15 or 18 feet down the driveway.
It's hard to describe but that's the best I can do. What do you think?
Old 10-28-2009, 09:40 PM   #17
Capthuff
AMP Racing member
St. Jude Donor '09-'10-'11-'12
Capthuff's Avatar
Spinning aint winning....
Long tubes and a street tune will really liven it up...
__________________
99 red coupe - 427 LS7
10.00 index car and bracket car
Capthuff is offline   Reply With Quote
Reload this Page Performance increase
Tags
2004, 87, corvette, increase, performance
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cold air induction for C6 afdl62 C6 Tech/Performance 36 09-09-2005 03:45 PM
Need real answer: Does removing the cat's increase power? QUIKAG C5 Tech 66 12-14-2002 07:14 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
