Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-23-2009, 03:41 PM   #1
Phanni
CF Senior Member
Phanni's Avatar
Send a message via AIM to Phanni
Default Removing and installling sun visors
Anyone got any tips?
I got one done, but what a PITA..
Phanni is offline   Reply With Quote
Old 10-23-2009, 04:15 PM   #2
PETE O.
CF Senior Member
PETE O.'s Avatar
There's a sticky on that proceedure. It's really a piece of cake. All you need is a small screw driver and a twist of the visor.......
PETE O. is offline   Reply With Quote
Old 10-23-2009, 04:28 PM   #3
RedSoxFan
CF Senior Member
RedSoxFan's Avatar
One tip I can give you is to pull the inner ring (for lack of a better description) out after you've disengaged the visor arm. When I installed my homelink visor this wasn't part of the installation instructions but it made it a heck of a lot easier to fish the wire out after removing that ring. Then just pop it back in and re-install.
RedSoxFan is online now   Reply With Quote
Old 10-23-2009, 06:45 PM   #4
JropTop
CF Senior Member
JropTop's Avatar
Here ya go!!!!!!!!!!!!
The following steps describe the process for removal and reinstallation of your Corvette Sunshade.
REMOVAL OF SUNSHADE : (Caution: Take great care to avoid damage to the plastic bezel, rod or other parts of the sunshade. These parts are reasonably fragile and easy to damage. Protect these parts and do not force the removal.)
To remove the driver side sunshade, tilt the sunshade down toward the windshield as you would to block the sun.
Insert the blade of a flat head screwdriver in the slot on the inner plastic bezel at the end of the rod (Install protective sleeve on this rod) protruding from the sunshade into the roof area.
Now rotate the sunshade clockwise toward the driver’s side window. The placement of the screwdriver will cause the bezel to rotate when the sunshade turns and presses against it. Pull down on the sunshade arm as you rotate it until the sunshade stops.[the first tab disengages]. Push up on the sunshade and continue rotating the sunshade until the sunshade with the inner bezel disengages from the mounting bezel.
In this position the sunshade will come free from the roof-housing. Expose the wiring connector (This is located 2-3” from the end of the rod.) Disconnect the connector. (you may have to remove the roof bezel to get the connector to come free. This bezel is a press-fit.)
REINSTALL SUNSHADE:
JropTop is offline   Reply With Quote
Old 10-23-2009, 06:54 PM   #5
atmsrus1
CF Senior Member
atmsrus1's Avatar
See if this works for ya.
http://www.pc-surgeon.net/images/cfo...eplacement.pdf
atmsrus1 is offline   Reply With Quote
Old 10-23-2009, 08:41 PM   #6
Phanni
CF Senior Member
Phanni's Avatar
Wow Thanks guys....
Old 09-21-2010, 11:52 AM   #7
Jesse Asis
CF Senior Member
Jesse Asis's Avatar
Thanks JropTop, after spending 30 mins. studying the mount (no screws, no instructions, no clue as to how that suckers was attached). I went to the forum to see if someone posted an answer. Again thanks to guys like yourself, you shared what could of been a damaging situation into a (2 min. removal). The visors are not built well, the leverage breaks the area just above the mirror breaking the particale board body. Little more engineering could have had a metal plate or re-inforcement tabs to support just swinging the visor down from the end and breaking that board. Oh well, ordered new ones at $95 bucks per side, should last another 10 years (I hope..) Thanks again guys, your the best. Jesse
Jesse Asis is offline   Reply With Quote
Old 04-08-2012, 11:07 AM   #8
Praetorian27
CF Senior Member
Praetorian27's Avatar
This is exactly what I was looking for! I know I'm resurrecting an old thread...but I just wanted to say that once again, this site proves to be without question, the BEST car user / fan forum I have ever seen! No matter what my question, or problem with my C5, I get precise, quick and friendly help. Rock on Corvette guys!!
Praetorian27 is offline   Reply With Quote
Old 04-08-2012, 11:38 AM   #9
CactusCat
CF Senior Member
Oldtimer
CactusCat's Avatar
Quote:
Totally!!
CactusCat is offline   Reply With Quote
Old 08-30-2012, 06:34 PM   #10
512BB
CF Senior Member
Support Corvetteforum!
512BB's Avatar
Quote:
Originally Posted by atmsrus1 View Post
Thank you! What a life saver and kudos to you and this forum.
512BB is offline   Reply With Quote
Old 08-30-2012, 08:51 PM   #11
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
Got to love the info available on the forum. Lots of very knowledgeable people here.
Vetteman Jack is online now   Reply With Quote
Old 01-19-2014, 08:27 PM   #12
LaVern Slusher
Junior Member
I have the old visors out but reinstalling them i can't get the visor flush with the bevel. can any body give me some tips on reinstalling them
LaVern Slusher is offline   Reply With Quote
Old 01-19-2014, 10:22 PM   #13
jfaxas
CF Senior Member
jfaxas's Avatar
Juan C. Faxas jfaxas
jfaxas is offline   Reply With Quote
Old 01-20-2014, 02:38 PM   #14
Jesse Asis
CF Senior Member
Jesse Asis's Avatar
If I recall, stick a medium screw driver into the body of the plastic piece that goes into the hole, and twist it back into the hole, it will lock... If you took it out, just reverse the process, play with it, it goes back in... Good luck.
Old 01-20-2014, 03:43 PM   #15
DanSavage
CF Senior Member
DanSavage's Avatar
Quote:
For those of us with the Shale interior (`03 AE & `04 CE), buying replacements is not an option because GM no longer stocks these and there are no aftermarket replacements.
So, I did the surgery required to rebuild mine.
I documented the process here: http://forums.corvetteforum.com/c5-g...n-visor-2.html
DanSavage is offline   Reply With Quote
Old 02-03-2014, 06:53 PM   #16
psint
CF Member
psint
Send a message via AIM to psint
psint is offline   Reply With Quote
Old 04-08-2014, 03:23 PM   #17
chuckeb84
CF Senior Member
chuckeb84's Avatar
Quote:
Originally Posted by psint View Post
Will a c6 visor fit a C5 it has the home link
chuckeb84 is offline   Reply With Quote
Reload this Page Removing and installling sun visors
Tags
07, 2004, 2005, c3, c5, c6, corvette, homelink, removal, remove, removing, sun, vette, visor, visors
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
wtb... rear lowering bolts. Tommyxgun C5 Parts for Sale/Wanted 5 04-02-2014 02:20 PM
Baby's Got New Shoes! C2Jeff C1 & C2 Corvettes 8 02-28-2014 09:47 PM
Shes born!!! ssidekickbp C7 General Discussion 30 01-18-2014 09:08 AM
Preakness picks? DrGas Off Topic 1 05-18-2013 05:31 PM
Video Test LS1 REDBIRD Testing 1 04-29-2013 01:21 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
