Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-15-2009, 03:48 PM   #1
BIGG DOGG
CF Senior Member
BIGG DOGG's Avatar
Default Suspension Squeaks - What to do
Two of my C5 Convertibles have developed pronounced squeaks when going over bumps. 1998 with 45K miles and a 2001 with 70K miles. Obviously, I suspect sway bar bushings and other suspension bushings. Does anyone know of a solution by "lubrication"? The help is much appreciated. Squeaks are in both cold and warm weather at this point, albeit louder in the cold weather.
Thanks, Rich
BIGG DOGG is offline   Reply With Quote
Old 08-15-2009, 04:30 PM   #2
TheBigDog
CF Senior Member
Need to change your forum name ther is only one BIG DOG
The Big Dog
TheBigDog is offline   Reply With Quote
Old 08-15-2009, 04:42 PM   #3
00 Rooster
CF Senior Member
St. Jude Donor '08
Support Corvetteforum!
00 Rooster's Avatar
Quote:
Thanks, Rich
could be squeaking at the sway bar bushings. you could put some dielectric grease in them. I did that when I upgraded to the c6 z51's. hope that helps.
Quote:
The Big Dog
come on kids...let's play nice
00 Rooster is offline   Reply With Quote
Old 08-15-2009, 08:29 PM   #4
StewB66
CF Senior Member
StewB66's Avatar
[QUOTE=00 Rooster;1571150111]could be squeaking at the sway bar bushings. you could put some dielectric grease in them. I did that when I upgraded to the c6 z51's. hope that helps.QUOTE]
I had the same thing on my '98 Z51. It's a pretty simple job to loosen the bushing clamps and grease the bushings...might as well change to poly bushings while you are there. Cheap and easy!
StewB66 is offline   Reply With Quote
Old 08-15-2009, 08:33 PM   #5
renegad44
CF Senior Member
renegad44's Avatar
Quote:
Sounds like a great plan.
renegad44 is offline   Reply With Quote
Old 08-15-2009, 08:48 PM   #6
CHUXDRM
CF Senior Member
CHUXDRM's Avatar
I just had the same "squeaky" problem show up on an '02 w/ 50,000 mi. I did some searching here (there's been a lot of info written), everything seemed to point to the sway bar bushings. I took them off, cleaned them up, lubed with silicon grease, but squeaks were still there. I could tell the squeak was coming from the right rear suspension. So I removed the wheel for better access, and sprayed silicone lube on each side of the upper and lower A frame bushings, tried again, squeak was gone. I was so proud! When I took car out 2 days later, squeak was back.
So now what to do? At least I've got the culprit located. I just don't know whether to spray the heck out of it with the silicon lube, or is there some other lube that would be better? I DO NOT want to disassemble the complete suspension to get into the bushings! Whatever I do, I figured I'd do all the suspension bushings at all 4 corners.
Any thoughts?
CHUXDRM is offline   Reply With Quote
Old 08-16-2009, 03:02 AM   #7
JOHN/WS6
CF Senior Member
JOHN/WS6's Avatar
Send a message via MSN to JOHN/WS6
i have the same problem, but is in the Right front side
JOHN/WS6 is offline   Reply With Quote
Old 08-16-2009, 03:14 AM   #8
JMc
CF Senior Member
JMc's Avatar
Location: "This is not a psychotic episode, but a cleansing moment of clarity."
I've got approx 76k mi on my '02 vert. It was making very obnoxious creaking sounds going over speed bumps, in particular.
My dealer tried lubing the sway bar bushings. No good. Still creaked. Wound up replacing the sway bar links and bushings. Also the front leaf spring, which was cracking. Tie rod ends in the rear were loose so they replaced them, too. All under warranty. Now the car rides like it's got new tires.
JMc is offline   Reply With Quote
Old 08-19-2009, 04:38 PM   #9
BIGG DOGG
CF Senior Member
BIGG DOGG's Avatar
Has anyone applied lube to the bushings that has really worked in removing the noise issue? If so, what kind of Lube?
Old 08-19-2009, 05:01 PM   #10
ajg1915
CF Senior Member
St. Jude Donor '08
ajg1915's Avatar
A good synthetic grease like that used to the caliper pins works well because it's water resistant so it won't wash off.
You can pick it up at any local auto store.
ajg1915 is offline   Reply With Quote
Reload this Page Suspension Squeaks - What to do
Tags
2000, 98, body, bushings, c4, c5, car, corvette, shocks, squaks, squeak, squeaking, squeaks, squeks, suspension
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
M3 v. CTS-V on a back to back Test Drive...Plus C6 review Adam Bruce C6 Corvette General Discussion 26 09-17-2004 10:16 PM
What are the best suspension mods to do? yellowc4LH C4 Tech/Performance 28 03-28-2003 12:23 AM
What is the best suspension setup??? Moundir Autocrossing & Roadracing 27 11-05-2002 04:39 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
