stuck after washing
Old 08-08-2009, 06:48 PM
CREEKROW
6th Gear
CREEKROW's Avatar
Default stuck after washing
Hi, Has this happened to anyone else? After I wash my 2004 Z06, If I don't drive it for a few days, when I start out back out of garage the car is stuck in place, like the wheels are rusted in place. I have to give it some gas to get it to move. Just letting the clutch out the car wiil stall. When it starts to move you can fell it break loose.
Old 08-08-2009, 06:50 PM
VinnyT
VinnyT's Avatar
Did you have the emergency brake applied when parked?
Old 08-08-2009, 07:08 PM
CREEKROW
6th Gear
CREEKROW's Avatar
No.the E-brake was not on, The 2001 Z06 that I had never did this.
Old 08-08-2009, 07:12 PM
VinnyT
VinnyT's Avatar
Sounds like a brake caliper is sticking. When you wash it it "freezes" to the rotor after it is parked. Next time this happens, and you get it to finally pop from freezing, stop and check your rotors. The one that freezes will leave a mark on the rotor that looks like an imprint/outline of the pad in question.
Old 08-08-2009, 07:14 PM
Blue 92
Support Corvetteforum!
Blue 92's Avatar
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
How different are the brake setups, pads and rotors, between the two cars?
Sounds as if the 04 may get a bit of rust build up after you wash it.
Old 08-08-2009, 07:40 PM
bartsky
bartsky's Avatar
YES! I have done this several times. I wash my car then pull in garage to finish detail. If I don't drive it for about a week, when I do go to pull out, it is stuck. I actually had to get out and push it back. I initially thought it was tires stuck to garage floor from soo much Armor All even on the edges. I think its is the water between the rotors and brakes though. I guess it creates a lil rust and sticks?
Old 08-08-2009, 07:52 PM
Patman
Patman's Avatar
Received 1,920 Likes on 1,192 Posts
I've had this happen as well! It's not too often that I wash it and put it in the garage without driving it around the block, but every time that I have done this the brakes have been stuck in position and I had to give it more gas than usual to unstick them. It's a bit unsettling when you hear that pop, but it hasn't caused any problems over the years, so I'm not worried.
Old 08-08-2009, 08:46 PM
TPA Z06
TPA Z06's Avatar
That's the key - take it for a quick spin and you won't have that problem.
Old 08-08-2009, 09:00 PM
rebelheart
rebelheart's Avatar
The high metallic content of the ZO6 brake pads actually begins to rust to your rotors,not really a problem though.Dont know if you alllowed it to sit for weeks like that though.
Old 08-09-2009, 03:42 AM
CREEKROW
6th Gear
CREEKROW's Avatar
Thanks everyone for the info, the next time it happenes I'll check to see if there is a mark on the rotor. This is why this Forum is great.
Old 08-09-2009, 09:35 AM
rebelheart
rebelheart's Avatar
My wifes speed Miata does the same thing!Just the metallic pads.
Old 08-09-2009, 09:39 AM
pewter99
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
happens all the time if you pull right in and set the brake or don't allow the water to drain out of the rotors enough...try backing up and then pulling forward first to drain the water out of the rotor vanes..they hold more than you think
To stuck after washing
Quick Reply: stuck after washing
