1997-2004 C5 Sequential Taillights Kit! New product from RPI Designs!
Platinum Supporting Vendor
We've got more in stock and ready to ship, thanks!!
Josh,
Since mine shipped on Monday should I be looking for it tomorrow? How did it go out? Mr. Brown or USPS?
I bought these when they were first introduced about five years ago. They still work fine.
Also installed the rapid 3-pulse center brake light mod at the same time.
The downside is, you never get to see them work!
Here's a How-To link that shows the easy installation assuming its the same product I bought years ago.
http://dana60.com/rickko/corvette/WEP/sequencer.html
..rickko..
..rickko..
..rickko..
..rickko..
www.webelectricproducts.com/sts.jpg Click on the online instructions for the "STS-2C5/6PW Corvette Installation (Pre-Wired Harnesses)". It shows some pics of the current model.
I also have the center brake light pulser too. The current version has the repeat-delay feature which I really like over the old originals.
Just ordered a set
We sold our 66 Tbird today with "real" sequential tail lights.......I will be installing this on my Wife's 2000 C5
Stan
Stan
The 97-04 C5 Corvette sequential harnesses will convert the taillights on your 1997-2004 Corvette into Sequential Turn Signals. The 97-04 C5 Corvette sequentail taillight kit contains two pre-wired harnesses that simply plug into your existing sockets. Return to stock operation at any time by unplugging the harnesses. It doesn't get any easier that this!
These harnesses feature sophisticated electronics that automatically adjust the sequencing speed to match the turn signal flasher in your car. While other products offer you fixed timing or complicated manual adjustments, our modules sense your car's flasher speed and adjust the sequence timing for you. Want more separation between individual lamps? Just put in a slower flasher!
You will not find a nicer C5 Corvette sequentail taillight kit!
Available here: http://rpidesigns.com/shop/item.asp?itemid=1658
#34
Installed seq flasher on sons stang
My son has an 05 stang. 3 lights but the center most one on each side wired only as a taillight. The stang kit he ordered had an additional lead which fit into the middle light which already had a 2 filament bulb.
Seq TS/brake lights are more effective on the stang than the vette as it has 3 not 2 lamps.
The sequence is centermost first, then add middle, then add outer. When applying brakes they do the same but MUCH FASTER almost at the same time.
An ASIDE. He was pulled over by the local cops for "dazzling lights".
This ridiculous infraction actually exists in the MD vehicle code. No definition af dazzling lights are given so the LEO can probably cite anybody with LEDs etc. Amazingly the 2010 stangs are factory equipped with "dazzling lights" ie. sequential turn signals. MD cops now have a lot more vehicles to stop.
#38
Well if i can't get an answer on anything i will move on and buy something from another vendor. I hate feeling ignored when i've got $ to burn and interested
#40
I have had these for several years now, get quite a few comments on them.
One of the cool things is that when you appy the brakes, the CHMSL comes on first due to it being an LED, then immediately the inside light, followed by the outside light. You get the "three light effect" even with our OE set up when you install the sequencer.
