Without Runflats
Without Runflats
So I hear alot of guys saying they ditched their RFs to gain a better ride and less noise. My Goodyears are ready to be replaced but I am one of those paranoid types that worries about driving without a spare or RFs. We travel alot in the car and I am the type who brings along almost every tool AND the shop manual! (But I would like a better and more quiet ride)
So if I rid myself of RFs what can I do to make myself feel better about not having tire trouble on the road with no spare? Or do I just rely on AAA and worry less? (And maybe I do worry too much as in 25 years of driving, I have only ever had one blowout and two flats)
Help me out with a decision.... RFs or not?
If you are totally paranoid - there are aftermarket extended mobility tires that will give you a better and quieter ride than you've experienced with the OEM Goodyear EMT's.
Michelin and others make extended mobility tires, the biggest difference is the distance in which you would be able to drive with zero air pressure in the tire.
The Goodyear EMT is the only tire certified for 200 miles with no air. Most of the others say their tires can go no more than 50 miles.
Here's an interesting article that de-bunks some of the myths about the Goodyears and explains the differences between brands.....
http://www.corvetteactioncenter.com/...Run+Flat+Facts
Did you know that Goodyear OEM Runflats get 3 mpg better mileage than non-runflats and at least 2 mpg better than other runflats?
Despite the "bad press", they DO handle great (better than Goodyear GS-D3s according to the magazine Corvette Enthusiac) and look great (mainly due to their being the widest tire in that size, the 275s are wider than the ZO6's stock 295s). No doubt they accelerate (hook up) worse and ride worse than non-runflats. They also last a long time for a performance tire (long tread life).
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
No run flats here..
Do I worry about a flat....No.
Here is what I always carry in the car..
1. Z06 pump kit.
2. Tire plug kit.
3. small 4 way tire wrench.
4. A small sissor jack.
5. AAA.
6. Cell Phone.
I think if I was to get a flat I would have it covered unless the tire is trashed.
and all this fits in the center cubby...lol
1. Z06 pump kit.
2. Tire plug kit.
5. AAA.
6. Cell Phone.
Ride in someone's car who has switched to non-runflat tires, you will not believe the difference. I switched to Toyo's and the radio can be heard with out raising the volumne so much that the sound is distorted. You can also have a conversation with someone in the car without yelling. Still somewhat worried about having a flat but will address that when it happens. Think about it, before having runflats did you worry about flats, and did you always check the air in your spare.?
In the 3 years and only 7,000 miles I've had the car, I've had 2 flats. I'm sticking with runflats, and like the tread wear, width, and looks of the OEM's better than any.
If you are scared that one day (tomorrow, next week, one year, during the life of the tire) you might get a flat, then stick with the run flats. If you want to experience what these cars are capable of, and talk to your passenger without yelling, get some non RFs.
There is a reason GM didn't put these on the Z06!!!!
After burning up my rears (hard driving, and some drag racing) and eventually the fronts, I ditched the OEM run flats for Goodyear supercars (285 rears) and for BFGoodrich G-Force Sport (fronts). I can say that every aspect of performance has improved in my car, (ride, noise, handling, grip, less rotating weight, not to mention about half the price). I do however, carry a small pump and slime (yes I know it can mess up the tire and even the tire pressure sensor for long term, but probably wouldnt care in an emergency). I've been lucky and only had one flat the entire 20k miles Ive had my car and that was when I DID have my runflats lol. I have been on two road trips (700 and 850 miles each, roundtrip) non runflats and no problems (knock on wood). Another thing, I don't feel as guilty burning rubber in non-runflats as I do in the runflats (my wallet doesn't hurt as much) My new set of Yokohama's on the new CCW rims I'm getting delivered next week are also non-runflat (and a lot thicker than stock too)
