***Interior & Exterior LED Upgrades for your C5***
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
This thread combines all of the LED products we offer into one post. If you have any questions or requests send me a PM or email me at Sales@jw motoring.com
These are the 194 sized LEDs used in the interior and license plate lights in the back. Replace those worn out yellow lights with our LEDs!! 100% plug n play and require no soldering, harnesses, or re wiring. The color options are red, white, or blue and each bulb has 5 LEDs on them. They are sold as a pair(2). On a C5 you need 6 pair to do a complete change. They replace:
Footwell lights- 1 pair needed
Rear License Plate light- 1 pair needed
Rear Hatch-1 pair needed
Side markers- 2 pair needed
Glove box lights- 1 pair needed
Prices are $15 shipped a pair (2 lights)
Order here: http://www.shop.jwmotoring.com/produ...4&productId=20
White- notice the LEDs on the bulb:
Blue on left white on right:
Now available in Red!
Banned Scam/Spammer
DRL/Front Turn Signal Area
Enhance the front end of that C5 with our LEDs.
Switchbacks
These LEDs will give you the amber for normal DRL operation and then white with the parking/headlights on. Hyperflash (rapid flashing) will be experienced when replacing your bulbs with LEDS. Available in 60 LED versions.
$25 each shipped (1)
Order here: http://www.shop.jwmotoring.com/produ...&productId=139
60 LED version
Watch the video of this bulb in action
Front Side Marker
Change the look of your side marker with out LEDs. We offer a 9 or 13 LED option. Both provide plenty of light Options are amber and white. White will be in stock soon. Starting at $19 a pair (2)
Order here: http://www.shop.jwmotoring.com/produ...&productId=147
We also offer clear corners for full use of these bulbs.
Order here: http://www.shop.jwmotoring.com/produ...&productId=141
Order here: http://www.shop.jwmotoring.com/produ...&productId=165
Switchbacks
60 LED version
Front Side Marker
Banned Scam/Spammer
The kit comes with LED strips built right into the housing for a complete swap. These plug right in after unhooking this clip:
12 bright LEDs shine to provide the light you need in your cargo area
This kit includes the housing and we offer a $4 dollar refund for your old housings. Details will be included with shipment
Colors options include: Warm white, Cool white, Blue, and Red (limited availability).
Warm White:
Red:
Cool White:
Blue:
Order here: http://www.shop.jwmotoring.com/produ...4&productId=33
Warm White:
Red:
Cool White:
Blue:
Banned Scam/Spammer
Cove kit:
Fender Cove led kit comes with 2 waterproof led strips w/12 leds on each strip, remote control box and 2 extended range remotes. The kit is also fused for protection. You have the power to control when these come on! Kit is completely wired with just 2 electrical connections to make near the battery. No wires or switches to mount inside the car. Approx install time is 1 hr. This mod turns heads and really gets your vette noticed! Available colors are red ,blue, white, yellow, green, amber or orange.
Order here: http://www.shop.jwmotoring.com/produ...4&productId=28
Footwell:
Footwell led floodlights; Change out those weak factory bulbs to these very bright footwell led strips. Plugs directly into the factory housing but you can mount them anywhere you like. Comes with adhesive backing but there are many mounting options. These are the brightest and most effective leds I have found! Kit comes complete with instructions and leds for both footwells.Colors available are red, blue, green, and white.
Order here: http://www.shop.jwmotoring.com/produ...4&productId=29
Led door reflector kit swap:
Led door reflector kits; Send me your good door reflectors to be converted to a 9 led reflector kit. Intructions for sending the unit will be provided after sale. Kit comes complete with wiring harness to wire into the footwell lights so they come on when the doors are opened or the interior lights come on. Wiring harness also has extra connections for optional "puddle" led strips on the bottom of the door. Reflectors only work with red but the puddle lights can be any color. Door panel and courtesy light panel removal required for wiring. Complete instructions included. Covers both doors.
Order here: http://www.shop.jwmotoring.com/produ...4&productId=30
Footwell:
Banned Scam/Spammer
We are now offering a LED Conversion for HVAC, Radios, and Button inside of the C5. This is what is offered:
HVAC - $195 + shipping. A $100 refund will be given to HVACs received back in good condition for a core exchange
1. Tear the unit down and clean all the buttons and the Faceplate
2. Fix the dim/dark display
3. Remove all stock incandescent bulbs and install LEDs and
required modifications
Order here: http://www.shop.jwmotoring.com/produ...5&productId=42
Radio - $215 + shipping. A $100 core refund will be given to HVACs received back in good condition for a core exchange
2. Remove all stock incandescent bulbs and install LEDs and
**This procedure takes about 5 hrs to complete.
Order here: http://www.shop.jwmotoring.com/produ...5&productId=43
The Dim Display repair is $45 + shipping. Pm for details//ordering.
We can also convert all the buttons, $1.50 a bulb, Except for the following;
1. Traction Control Plate - $ 35
2. HUD Switch Assembly - $ 45
3. Trunk Release/Fog Light Assembly - $ 35
4. Auto Dimming Mirror Map Lights - Red $35, Blue or White $45
Specifics for ordering:
1. Red, White and Blue LEDs are in stock, other colors will require 7 day lead time
2. Typically a one day turn around time for one unit, two days for both
3. I have a limited supply of spare buttons to replace ones that have lost some of the blue film on the inside, $15 a piece
4. Send me an email to Sales@jwmotoring.com with everything you want done for a quote. This is important!!
Here are various shots with LEDs. Look how good those LED's make the stock HVAC and Radio look!
Night Owl for life
Received 3,248 Likes
very cool stuff.
St. Jude Donor '11-'12-'13-'14-'15
Thanx!!!! I'm rather proud of that one actually.... I wish the colors would have shown up better, they are more vibrant then those pics depict. You'd think after all this time I would have learned how to take good pics of these things
Tim
Tim
