Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-22-2009, 05:52 AM   #1
uracowman
CF Senior Member
uracowman's Avatar
Send a message via AIM to uracowman
Default How to replace driver side mirror
My driver side mirror got some water under it and is totally ruined and the black plastic lining around the mirror is ruined as well. I was wondering how you would replace this. Does GM sell a new mirror, or does the entire mirror unit need to be replaced?
uracowman is offline   Reply With Quote
Old 05-22-2009, 07:55 AM   #2
Jet-Jock
CF Senior Member
Support Corvetteforum!
Push in on one edge of the mirror glass titling the mirror case to allow finger access. (Upper right edge push in.) Grasp the glass firmly and pull the case from the mirror body. It mounts with a cross bar mechanism that is pressure seated.
Remove the two jackscrews from the mirror glass case. Bend the jackscrew over. PRess down on the side of the jackscrew popping the jackscrew from the mirror glass case. Save the jackscrew.
There is a wire assembly attached, with the mirror loose, disconnect the wire.
The jackscrew springs must be positioned down compressing the fingers at the bottom of the jackscrew. Push to install into the mirror motor. Rotate both jackscrews to position the ball flanges to be inline with the attaching hub. Upper is vertical and outside is horizontal.
Connect the wire to the new glass case.
With a gloved hand and your palm, press firmly on the center of the mirror glass until it engages onto the motor.
Be gentle.
Right and left side are different, be sure to order the correct glass.
Let me add some specifics about the installation for right and left mirrors:
Right mirror. Rotate the mirror glass case down and press firmly on the lower side engaging the mirror glass case to the lower jackscew.
Left mirror. Rotate the mirror glass case up and press firmly on the upper side engaging the mirror glass case to the upper jackscrew.
Rotate the mirror glass case and press firmly on the outer side engaging the mirror glass case to the outer jackscrew. The jackscrews will give a clicking noise when properly seated.
Last edited by Jet-Jock; 05-22-2009 at 12:32 PM. Reason: Sorry wrong procedure, had to retype it.
Jet-Jock is offline   Reply With Quote
Old 05-22-2009, 12:32 PM   #3
Jet-Jock
CF Senior Member
Added a little more FSM explanations.
Old 05-22-2009, 03:09 PM   #4
uracowman
CF Senior Member
uracowman's Avatar
Be gentle.
can the mirror be purchased from gm? I remember the last time I called the dealership, they said the entire mirror including the housing the mirror goes into (the body piece that ispainted), had to be replaced. It cost something around 300 dollars
Old 05-22-2009, 04:07 PM   #5
Jet-Jock
CF Senior Member
Quote:
Yes.
Mirror glass Right, 97-04 MSRP 89.35 Online GM price 54.83
Mirror glass Left, 97-04 MSRP 81.15 Online GM price 49.78
(I used GMPartDirect.com for pricing and availability.)
Reload this Page How to replace driver side mirror
Tags
1988, 2003, c3, c5, corvette, drive, driver, glass, install, left, mirror, mirrors, remove, replace, side
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
