The $40 fix for broken side bolsters [pics]
Old 04-18-2009, 07:06 PM
  #41
ksvette74
ksvette74's Avatar
did my lumbar this way in the walmart parking lot, worked nice!! I just used the fitting on the end of the long hose to attach to my old air line, sealed and worked great! Probably should go back in and shorten the hose as I have plent of it tucked in there, lol.
Old 04-18-2009, 07:18 PM
  #42
damilleniumboy
damilleniumboy's Avatar
Mine are gone too on the driver side. I will work on that one of these weeks.
Old 04-18-2009, 07:25 PM
  #43
NorCalVette Kid
NorCalVette Kid's Avatar
St. Jude Donor '09
Originally Posted by csexton
Great write up and bookmarked
Chuck
Old 05-01-2009, 05:35 PM
  #44
ericw
ericw's Avatar
Many thanks for the great write-up!
Just finished replacing ALL the bladders on both seats; didn't know what I was missing, and saving a thousand bucks sure is a bonus!
One more piece of perhaps useful information: I removed the metal cuff loop, and trimmed the cuffs approx. 1/4" past the actual bladder inside. Now - the cuffs still have to be folder/rolled up to approximate the original bladder size, but they won't stay folded or rolled up very long in the lumbar support positions - and obviously they still have to expand and contract. My answer was to put the folded cuff in an old sock! The use of some adhesive-backed hook-and-loop (Velcro) fastener strips then kept the sock with it's bladder payload in place.
Old 05-01-2009, 05:53 PM
  #45
ksvette74
ksvette74's Avatar
it will leak overtime if u don't use a diffrent fitting like the op said. However, with the cuffs from walmart there is a straight fitting in there. Just pull off the excess hose, and the t-fitting and u can use the straight one. It fits right into the old air hose in the seat. To get them to stay where they are supposed too, I cut off the plastic tab so there is just a hole in the plastic. U can then use the velcro in the cuff to attach to itself through that hole. It does not feel like a strong attachment, but it only has to keep it in place, as the seat being zipped back up will hold it where it is supposed to be. I have been problem free since using this fix. I now have it in both my seats. I tried it in the side support, and I found the cuff was too big for personal taste. I would like to try to find a pediatric cuff for that application.
Old 05-04-2009, 10:48 AM
  #46
ericw
ericw's Avatar
Right next to the recommended cuffs on the shelf at Walmart, I found a "manual" blood pressure kit - this kit has a smaller cuff, at the same $9.95 price for the whole kit.
The kit also contains a pressure gauge and inflator bulb, both of which can be discarded, and the cuff can be cut down even more by carefully snipping around the bladder area. Only problem is that the cuff has TWO hose attachments (one for the bulb and one for the gauge), one of which then has to be plugged.
Much better fit in the side bolster application - only used one fold.
Old 05-04-2009, 12:45 PM
  #47
mcgilles
mcgilles's Avatar
I saw the same thing and almost went for it. then I decided that the single cuff might work better. that and I think my wal-mart only had 3 of the other ones. but after doing the mod I agree with you, that one would have worked better.
Old 05-05-2009, 08:53 AM
  #48
clif
Support Corvetteforum!
clif's Avatar
St. Jude Donor '09-'10
Awesome! I love this forum! I need to do this on my driver's seat!
Old 05-13-2009, 03:52 PM
  #49
zz28zz
zz28zz's Avatar
Default Another fixed lumbar
Just finished repairing the drivers seat using the Walmart kit (~$10) that has the stethoscope, bulb pump, press gauge, and of course the cuff. After looking at both cuffs at Walmart and comparing them to the original bladders, I'm thinking the kits are the way to go. I'll try and upload a couple of pics when I figure out how to do it.
Old 08-04-2009, 10:54 PM
  #50
D3kennedy
Cruising
D3kennedy's Avatar
Used the large ones on the back and the small ones with the stethoscope on the sides
duct tape was there to hold them up, i used a little rtv sealant on the backs
Old 08-04-2009, 11:09 PM
  #51
olbear1962
olbear1962's Avatar
Great remedy, very good thank you for the logical fix. Make life easier for the rest of us when the time comes. Much appreciated
Old 08-05-2009, 12:02 AM
  #52
Jacks02
Jacks02's Avatar
Another reason why this forum is so valuable! Thanks for the write-up!!
Old 08-05-2009, 07:33 AM
  #53
WvCorvette
WvCorvette's Avatar
Nice...
Old 08-05-2009, 07:51 AM
  #54
Florida Mike
Florida Mike's Avatar
That is awesome! I love how some of you guys think! Not all of you mind you but at least some.
So having never done this before...how much extra room is in the seatback and bolsters? I am wondering if you could put more cuffs in there for added support or in differing locations?
Or does one cuff pretty much fill up the void?
Mike
Old 11-05-2009, 11:19 AM
  #55
Padrino
Padrino's Avatar
YES!!
Old 11-05-2009, 11:28 AM
  #56
vette.mix
vette.mix's Avatar
Old 11-05-2009, 04:51 PM
  #57
srs244
srs244's Avatar
St. Jude Donor '09-'10-11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Originally Posted by jdmvette
damn cool idea!
To The $40 fix for broken side bolsters [pics]
Old 11-05-2009, 08:29 PM
  #58
swpowell
swpowell's Avatar
This is just great. Everyday I find something on this forum that help me save money.
Old 02-14-2010, 09:56 PM
  #59
YellowFlash
YellowFlash's Avatar
CI 7 & 9 Veteran
Default Awesome fix!
Isn't this forum great ?
Old 02-14-2010, 10:00 PM
  #60
JeepTJ
JeepTJ's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Good stuff
Quick Reply: The $40 fix for broken side bolsters [pics]
