C6 Z51 rear Rotors and Brackets Installed--Thanks Gene Cully (Pics)
I got them from GM Parts House from Gene Culley and they are in perfect condition
I took Gene's suggestion and used "VHT Clear Coat" High Temp 500* Paint on the Rotors and brackets to keep them from rusting etc.
As an added bonus the C6 Z51 Rotors and Brackets do fit into a 17" wheel - Why? because I have MT ET Drag Radials on 17" C5 Z06 Front Wheels! (And I'll be posting this in the Tech section too)
So for any who wondered if they fit in the 17" wheel, well they do
I had to change them because my Rear WILWOOD rotor cracked:
Before
After
New Bracket
17" C5 Z06 Wheels,Drag Radials and C6 Z51 Rotors and Brackets
Enjoy the ride
Thanks,Matt
Before
After
New Bracket
Enjoy the ride
Thanks,Matt
Night Owl for life
Received 3,256 Likes
they look great. bigger is better.
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
I've seen a few C5's with the C6 z51 rotors, I like their look and they look great on your Vette
Cruise-In VII Veteran
can you edit your post stating the wheels are not OE GM, and they are installed out back
Big difference, will a C6Z51 rotor/bracket fit up front w/ the OE GM 17" wheel, barely, I've done it, but just in the shop, not road tested.
BTW: you might have missed a washer out back on those aftermarket lowering bolts
Then one day I saw a crack and I needed to change the REAR So I posted in the For Sale section and Robert Miller had a set he pulled off so I picked them up from for a good price and slapped them on.
Then a couple of weeks ago my buddy spotted a crack on this set too (But the opposite side from before)! So it might just be the REARS on the stock size Rotors from WILWOOD that have the problem
Either way I decided to go with the C6 Z51's and they seem a lot better than the stock size WILWOOD for the C5
Part numbers are:
Z51 Rotor (2) - Part# 89060329
Z51 Bracket(2) - Part# 88964167
I got them from Gene Culley GM Parts House (Here on the Forum) the total was $301.36 Shipped, signed, sealed and delivered
Thanks,Matt
I appreciate the compliment
Part numbers are:
Thanks,Matt
2. This post is not for the front I do believe that 17" wheels will have a really hard time fitting the C6 Z51 "FRONT" Rotors and brackets - again my post is only for the rear set-up the fronts have the WILWOOD C5 2 - Piece set-up
3. Washer out back? they were installed not by myself but by LAPD - so if you see something missing in my pic make it clear so I can fix it if need be
Thanks for the close eye and catch but I need some more info on your statements
Thanks,Matt
Matt, the "do C6Z51 rotor/brackets fit w/ 17" fronts" has been a big debate for the past few years, that's all
the lowering bolt is prolly fine, just looks like it's missing a washer
Hey thanks it was a seemless and easy swap out, less than an hour to do the cahnge!
Part numbers are:
Thanks,Matt
Part numbers are:
Thanks,Matt
Do you know how big a C6Z06 rear rotor is ? I need to change my rear rotors to something with more clamping force to hold my car on the launch on my 2-step before I hit my transbrake .
Is a C6Z51 caliper any bigger than a C5 rear caliper ?
Thanks , Mike
How much bigger are the C6 Z51 rear rotors compared to a stock size C5 rear rotor ?
Thanks , Mike
Thanks , Mike
First remember that I am utilizing my "STOCK" C5 CALIPER and only using the C6 Z51 Brackets and Rotors - I believe the C6 Calipers are the same size as ours.
The C5 Rotors are 11.8" in Diameter and the C6 Z51 Rear Rotors are 13" in diameter and from the end of the rotor and straight accross to the top of the caliper the dimension is 14.28125: (And this is why it fits into the stock C5 Z06 17" Wheels that I have my MT ET Drag Radials mounted on
As you can see in the pictures above that the C6 Z51 rotors are bigger by just looking at the before and after shots - take a look at the arm behing the rotor near the top of the rotor - you can see how much is showing with the C5 rotor and how much less is showing with the C6 Z51 rotor
I hope this helps some so if you need anything else let me know - you can also call if you'd like Cell 661-406-7516
I can take any measurement you'd like for the set-up
Thanks,Matt
Last edited by madmatt9471; 03-11-2009 at 06:21 AM. Reason: Change wording from C6 Z06 to C6 Z51 rotor in first sentence
Received 19,427 Likes
'20-'21-'22-'23-'24
New rotors look good - congrats on the upgrade.
