Trouble painting rear fascia
I just got done applying 3 coats to the bottom part of my rear fascia and there are some small pits and scratches on it that the spray paint didn't adhere to. Would it help to re-sand the bumper some and repaint?
if it's rattle can paint you can wipe it all off with some automotive laquer thinner and start over, you need to clean it with a wax and grease remover before you paint it again!
It sounds like prep is the culprit. What did you use to wipe it down to remove all contaminants?
proceedure sequence
First you wipe down the surface with a good wax & degreaser, then lightly sand / scuff the surface . This way you aren't rubbing the contanimates into the paint. The 'fisheye' is the result of the contaminates.
1 Post
St. Jude Donor '06-'07
The problem here is you used rubbing alcohol and then in the wrong order.
Bodyshops us special chemicals that remove oil, grease, silicones, waxes, etc before they get started.
The unfortunate part is you're now going to have to strip everything you just did and start over, you may have to even strip the entire fascia.
Go to an automotive paint supply store and get some Dupont Prep-sol. This is what the pros use because it's specially formulated to eliminate the issues you encountered.
Strip
Clean with Prep-sol
Sand
Prime
Paint
Clear
The final results all depend on the prep work....
Strip
Clean with Prep-sol
Sand
Prime
Paint
Clear
i would not use a green scotchbrite. Go to a NAPA and get a red one. It'll allow for a good surface to get the coats to stick to. that's what almost every bodyshop uses to assist in prep.
Lot's on here have painted the lower facia that way. I like the look...but if I do mine a bodyshop will paint it! Whatever works for the individual!
My father gave me a hand and sanded it down with a 400 grit and moved back up to 1000. He re-painted it and the area looks better, but not perfect. I just took the tape off, and I like the look. The rounded edges aren't as round as I like, but I can deal with that for now.
