oil pressure sending unit? how important?
#61
St. Jude Donor '09-'10, '14
Seems to me ET says all you have to do is take out the bolts and slide the manifold forward about 3 inches or so to do this job. Just enough to see what you're doing and be able to grab the sending unit.
I was going to use the method here in the video but it's not as easy as he makes it looks and leaves out a couple steps.
I got lucky, if that's what you want to call it and found the PO had cut a piece out and then re-secured it with tape. Not the way I would have done it, but in any case, I just took off the cutout and changed it in about 3 minutes, then put the piece back on in the same manner. It's hidden and was already like that so no big deal.
Mine never did go bonkers though mine was actually leaking oil.
#62
I opt'ed for the hole cutting in the fiber glass right above the oil sensor. Removing a perfectly operating intake manifold to me is just a waste of time. The hole gets covered up with the plastic cowell, so it doesn't really matter. Now the oil sensor re-locating kit is a good option, but again the intake must be taken off. Good luck on which way you go. Lots of guys who own vettes won't cut the hole (it's just a car) but they hold the vette to a higher level and will swear to God they won't do that.. Good luck..
#63
Because it's not if the sensor goes bad, it's when. And many members have changed theirs multiple times.
#64
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Just sounds funny.
#67
Thanks for the video!
Will attempt it this weekend.
A little afraid of getting dirt in the hole, the socket falling off when pulling it out (and then trying to get it back out if it falls off)
You made it look fairly easy, hope big hands won't be a big problem getting the new sensor back in.
#69
I did it using the process from the video. First thing to do is blow the area out with air, then I put a wedge between the cowl and the fuel rail bracket to better fit my hands in there and had a couple small lights and a good mirror to see what I was doing. What they do not show in the video is to use a coat hangar and bend it to get the connector off. It takes a couple tries to get it back on too. I put blue tape inside the socket to wedge the new one into it so I could install it using the socket. I hear your concern about the socket falling so use some duct tape from the socket to the swivel to the extention. All together the time it took was about 30 minutes because I kept getting more tools to help. If I do it again I will make my own video.
Reckon he got it done yet
But your information is helpful. Thanks
#74
I remember seeing that as well but no updates...sure sounds like it would be a worth while thing to do at a reasonable price...Hope that it happens.
#75
Always suprises me how some members seem to take offense when other members choose a different way of solving a given problem. What is easy for some may be very difficult for others. Just seems odd that when different methods are suggested some reply in a hostile manner. Do what works for you but there are always other ways to resolve the problem.
BTW, I have had three brass switches fail on my 99. So when I replaced the OEM, I am glad I bought a sender with a lifetime warranty :^)
#76
worth a look
#77
you guys can say what you want, I will be cutting out a nice neat square with my dremel, and I will get er done that way!!!
Vettman1 thanks for that great picture that's exactly what I needed to see to create my new access port...lol
#79
For me, cutting a hole is just making an access point that GM should of done from the beginning. Either way what ever floats anybodies boat, do it anyway you all want. Someone was asking and I was just giving options of what this forum is all about.. keep an open mind and we may all end up living in harmony, figure that one..
#80
It's a Mod like any other that enhances the car and makes it what it should have been. If done properly and neatly it will enhance your car.
Although moving it would be better for future replacement because then it would be even easier to replace.
Me thinks GM should have designed these things better if people are concerned about cutting a hole you will never see where a hole should be to begin with.
