Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-28-2009, 08:57 PM   #1
E.C.P
CF Senior Member
St. Jude Donor '07
E.C.P's Avatar
Default *** The Orginal UHMW "Rocker Saver" SALE ***
BACK MY POPULAR DEMAND
My orginal UHMW Rocker Savers ready to go for Only.
$60.00 shipped
Please sign up for your set via a post followed by payment via Paypal to
:nastyvette@sympatico.ca
Go from this :
To this is just 20 mins
THE ULTIMATE IN PROTECTION FOR YOUR 97-07 C5/C6 CORVETTE
Steep driveways and speed bumps can be hazardous, not to mention costly to the rockers on your Corvette.If your Corvette is lowered the constant worry of wrecking your expensive rockers is enough to drive you mad. Here at last is a well though out product designed and tested by a Corvette owner. My "ROCKER SAVERS" are made from an ULTRA HIGH MOLECULAR WEIGHT material that is"
EXTREMELY RESISTANT TO ABRASTION...HAS A VERY LOW COEFFICIENT OF FRICTION
SELF LUBRICATING / NON -TOXIC / EXTREMELY LIGHT [less than 1lbs for both peices]
IMPACT / VIBRATION / UV / AND CORROSION RESISTANT
EVEN IN CRYOGENIC CONDITIONS
Unlike powder coated aluminum that will flake at the first contact it has with a speed bump the colour of my product will always be there.Unlike aluminum that does not stand up well to asphalt and concrete, this material will not wear. Easy to install ,about an hour. Includes all stainless steel hardware & step by step installation instructions. Best of all you can still use your jacking pucks.The "ROCKER SAVERS' give you a 1/2" buffer zone between them and your expensive rockers.
Fits both C5 or C6
WILL FIT VETTE'S WITH ACI ROCKERS
Instructions for the ROCKER SAVERS :
ROCKER SAVERS
INSTALLATION INSTRUCTIONS; Tools needed;
13mm socket
5mm Allen key
5/32” drill bit
Phillips bit screw driver or bit
Hammer & punch
1. Locate the factory bolt just behind the rear shipping slot.
2. This bolt holds the rear aluminum shield. Remove this bolt.
3. Take the rail marked “DRIVER”. The largest of the four holes is your rear location hole.
4. Place the rail up to the hole where you removed the 13mm hex head bolt from and insert the supplied new 5mm Allen head bolt. We recommend LOCTITE on all the bolts and screws
5. Tighten until its snug.
6. Line up the rest of the rail, making sure you are not up against the rocker its self.
7. Once you are satisfied with your placement, remove the tape cover from the two way tape at the front edge, and press firmly into place.
8. Using a hammer and punch mark the 3 remaining holes and drill with a 5/32”drill bit.
9. Insert the 3 remaining SS screws and tighten starting from the SS 5mm Allen head through to the last SS Philips head screw.
10. Repeat same procedure on the passenger side.
ROCKER SAVERS BY ENGINEERED CORVETTE PRODUCTS
Thanks for all your support .
Manny Dasilva
Engineered Corvette Products
E.C.P is offline   Reply With Quote
Old 01-29-2009, 09:51 PM   #2
E.C.P
CF Senior Member
St. Jude Donor '07
E.C.P's Avatar
Ttt
Old 02-04-2009, 09:09 PM   #3
E.C.P
CF Senior Member
St. Jude Donor '07
E.C.P's Avatar
Bump
Old 02-04-2009, 09:36 PM   #4
itzza427
CF Senior Member
itzza427's Avatar
Do you still have the front guards??
itzza427 is offline   Reply With Quote
Old 02-04-2009, 10:12 PM   #5
E.C.P
CF Senior Member
St. Jude Donor '07
E.C.P's Avatar
Quote:
Sorry no . Its funny you know I stopped making them due to the lack of interest and now it seems everybody wants them
Reload this Page *** The Orginal UHMW "Rocker Saver" SALE ***
Tags
corvette, ecp, rocker, savers
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
