C3 to C5
C3 to C5
Greetings all, I have played mostly in the C3 area but have moved on from my 74 to a 50th anniversary convertable.
I searched the threads and found info on idle speed for modded engines but not for stock.
My engine idles about 850 rpm and when I shut it down it spins down longer than I am used to and has some valve noise.
I would appreciate some input on if this is normal or not and what some of the stock engines idle at.
Thanks in advance, Chris
Received 4,592 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Thanks for the info, I appreciate the reassurance.
St. Jude Donor '10
Been There, Done That
I'm glad you asked the questions. I went from an 82 to an 03 and had the same concerns. I love the 03, but miss the 82, it was so easy to work on. Good luck
Easier to work on, are you kidding, the 82' I had was the biggest PIA to change the plugs on I ever owned. Only had a dozen heat shields and other assorted junk around the exhaust manifolds.
Welcome to the C5 fold.
Too bad you couldn't keep the C3 and have the C5. You know what they say," He who dies with the most toys............"
Congrats! You'll enjoy the C5 but like Mikvi I miss the old '79 for the ease of maintainance and being a bit more robust in some areas. I don't think I'll go back unless I can own a '69 roadster and keep my 98.
Enjoy!
Enjoy!
Thank you all,
I had to sell the bike and the old Vette to swing the "upgrade" with the domestic chief executive. I really enjoy driving the C5 but nothing is like looking down the hood of the Stingray.
I never had much trouble working under the hood, but the dash is another matter.
Thanks for the warm welcome, Chris
Is your C5 a stick?
If it is, try holding in the clutch when you shut the engine off. That will get rid of the "death rattle" when the engine stops. It's a known "feature" of the C5.
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
Thank you all,
Put the lights up and look down the hood and fenders, very similar
to the C3 I think. Welcome and have fun with the C5.
If so, put it in Reverse (will only go with the key in the ON position) and holding the clutch in shut it down. It should be fine.
My 6-speed idles 650 rpm with AC on which it always is ON
Received 19,561 Likes
'20-'21-'22-'23-'24
Congrats on moving up to a C5. Hope you enjoy the car.
