Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-05-2009, 10:43 AM   #1
ELECTRONC5
CF Senior Member
Default Strange clicking/ dead battery
Yesterday I went out in the garage for some 'Vette' therapy..( dressing the leather seats). After I opened the doors, I noticed an odd 'clicking/buzzing' noise coming from the battery/computer area. Thinking it might be the battery, I tried to start the car and sure enough, it was dying and the car would not start. I did jump-start it using my other car and it's not had a problem since. The battery is a Die-Hard only 2yrs. old. I think an alternator only replaces the juice that's already present so I probably need a new battery. I've read good reviews on the Duralast. Do you think I did any damage by jumping it? Did I damage my custom tune? Thanks so much for your input.
ELECTRONC5 is offline   Reply With Quote
Old 01-05-2009, 10:47 AM   #2
poolboy
CF Senior Member
How long had it been sitting? The C5s are known to draw more power when shut off then other cars do. If your battery recharges then it is obviously still good. Don't worry about those noises you heard while the battery was drained - there are some relays that will 'chatter' as the battery drains towards zero. Get a battery tender to keep that battery charged during longer periods of no use.
poolboy is offline   Reply With Quote
Old 01-05-2009, 10:58 AM   #3
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
If you haven't started it for several weeks, it could just have drained down enough to not start the car. Take the battery to a place where they can test it and see if it is bad. I doubt that you damaged anything by jumping the car. And if you don't drive it often, the purchase of a battery tender would be a great idea.
Vetteman Jack is online now   Reply With Quote
Old 01-05-2009, 12:48 PM   #4
ELECTRONC5
CF Senior Member
Thanks so much for the replies! Do you think it will be OK to leave the battery in the car while it's being tested? It will start as normal and I could drive it over. BTW, one of my faults is that I don't drive it enough, especially in the winter...and it has been really cold lately....
Old 01-05-2009, 01:03 PM   #5
poolboy
CF Senior Member
if it is starting now then it will be fine to drive it to get the battery tested
Old 01-05-2009, 01:28 PM   #6
bencini231
CF Senior Member
bencini231's Avatar
Quote:
bencini231 is offline   Reply With Quote
Old 01-05-2009, 02:19 PM   #7
2vettes2go
CF Senior Member
2vettes2go's Avatar
just a weak battery. invest in a battery tender if you are not going to drive your vet at laeast once a week. had the same thing but i needed a new battery, since it wasem from 03.
2vettes2go is offline   Reply With Quote
Old 01-05-2009, 02:23 PM   #8
bartsky
CF Senior Member
bartsky's Avatar
Battery Tender Plus...
bartsky is offline   Reply With Quote
Old 01-05-2009, 02:49 PM   #9
TEXHAWK0
CF Senior Member
TEXHAWK0's Avatar
My experience with most batteries is that once you let them go completely dead, they are never the same again.
Maybe you should just disconnect the battery if you are not going to drive it for weeks at a time.
TEXHAWK0 is online now   Reply With Quote
Old 01-05-2009, 03:13 PM   #10
Dave68
CF Senior Member
Dave68's Avatar
From what I've seen, each drain that is severe enough so that the battery won't start the car will chop off about 3-5 months from the life of the battery. If you don't have an automatic charger, you might want to get one. It will come in handy, sooner or later. Most shops want you to remove the battery and take it inside so they can quickly attach their charging equipment (the battery must be fully charged to run a load test). Yes, it can be done outside, but that leaves the engine bay exposed to passer-bys.
certainly, a Battery Tender Plus is great to have if your car won't be started and taken out for a good run for two weeks or more, depending upon the age of the battery. Still, it's always a good idea to keep the battery as close to a full charge as possible.
__________________
2001 Mag-Red Coupe 6-Speed, 1SC, Z51, Born: May 17, 2001, delivered June 7th, 2001
315.9 RWHP 337.7 RWTQ (Dynojet) 6/8/02 (no mods)
328.8 RWHP 352.2 RWTQ (Dynojet) 5/22/04 with Halltech Stinger intake and CAI mod
Quad Round Borla Stingers 9/6/03
2002 Z06 airbox, 2013
Cold-air scoop mod 5/20/04
TPS Z06 shifter (replaced BPP on 12/26/11)
Intake install, oil trap, and CAI mod: http://www.conceptualpolymer.com/corvette_c5_corner.htm
Dave68 is online now   Reply With Quote
Old 01-05-2009, 04:57 PM   #11
killain
CF Senior Member
Oldtimer
Support Corvetteforum!
killain's Avatar
Send a message via AIM to killain
I had my 2003 at the shop last month and while it was there they 'Load Tested' the battery while the battery was still in the car, No problem !
killain is offline   Reply With Quote
Old 01-05-2009, 07:49 PM   #12
e6bailey
CF Senior Member
e6bailey's Avatar
My car does the same thing you are speaking of when the battery is dead. Once on the battery charger for about 30 Seconds it normally stops ticking. I have replaced my battery and still have this problem when I let the car sit for longer then about 3 weeks. When the time comes to get another new battery(sure I have drained this New once to many times), I am going to start keeping it on a charger like described above.
e6bailey is offline   Reply With Quote
Old 01-05-2009, 08:05 PM   #13
dobewillie
CF Senior Member
dobewillie's Avatar
15 bucks for a tender and a minute of your time to hook it up is well worth it
dobewillie is offline   Reply With Quote
Old 01-07-2009, 08:17 AM   #14
ELECTRONC5
CF Senior Member
Default battery problem
Thanks again for all the help, folks! I purchased an 800 MA Battery Tender, hooked it up and it worked just fine. It took overnite to do it, so the battery was really low. Now we'll see if it holds the charge. Either way, I needed to invest in a Battery Tender anyway. Hooked it up to the Duralast in my Mazda and it only took an hour and a half to reach full charge and it's almost 2 years old. That will be the next battery to replace the Vettes' DieHard (DieEasy)!
Old 01-07-2009, 08:38 AM   #15
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14
Quicksilver Vert 01's Avatar
Quote:
Don't short sell the DieHard battery. 800 MA is less than 1 AMP, and it's not intended to recharge a DEAD battery.
You shoult use a conventional charger, that can produce around 10 AMPS, to fully recharge a dead battery. I'll bet that your Mazda battery was not dead when you hooked it up to the battery tender.
Quicksilver Vert 01 is offline   Reply With Quote
Old 01-07-2009, 12:52 PM   #16
ELECTRONC5
CF Senior Member
Default Battery problem
Actually, you're correct.. the Mazda battery was fine and the car gets driven often. The Vettes' battery was holding the charge from the jump-start, so I'm hoping it will be OK. Whattaya think?
Old 01-07-2009, 01:33 PM   #17
Quicksilver Vert 01
I think you're good to go for now. Just keep the battery tender on the Vette, if it's not going to be driven for more than a week. The Sears DieHard is a strong battery.
Reload this Page Strange clicking/ dead battery
Tags
1999, 2007, battery, clicking, corvette, dead, weird
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Warning! Do Not Leave Owners Manual In The Car! Short-Throw C6 Corvette General Discussion 13 05-05-2005 08:27 AM
Dead C6 Wolfbane C6 Corvette General Discussion 40 12-22-2004 09:53 PM
healthy daily driver '97, turn key tonight after having set for couple hours = click, nada Red Gump C5 Tech 9 11-04-2002 04:10 PM
Weird Electrical problem. UKPaul C3 Tech/Performance 13 08-31-2001 08:37 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
