Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-01-2009, 02:36 PM   #1
Mag Red C5
Junior Member
Default Removing Rust from Rotors
I have a dilemma. My Corvette was perfect until the other night. Our temperature had been about 9 degrees, then suddenly went up to 70. My car cover was wet on the bottom from the condensation, and now my rotors are covered with rust. Aside from driving it, which I don't want to do right now, is there a safe way to remove this rust? I'm wondering if a little steel wool would work and not hurt anything. Any suggestions? I know it sounds crazy, but it just bugs me that there's rust on the rotors. Thanks for any help.
Mag Red C5 is offline   Reply With Quote
Old 01-01-2009, 02:38 PM   #2
hotwheels57
CF Senior Member
Steel wool or a 3M Scotch Pad (green grocery store variety) will remove the rust. Neither will remove any metal. Brand new cars at the dealerships will have rust on the rotors and they don't sit under wet car covers.
The fire path area will come clean with driving and braking. The rust won't hurt anything until you can drive it. It'll come back sooner or later if the rotors have no protective coating.
Maybe consider applying some high temperature paint on the hats and vanes to protect and beautify...at the cost of your labor on a nice weekend.
hotwheels57 is offline   Reply With Quote
Old 01-01-2009, 02:46 PM   #3
dougbfresh
CF Senior Member
Why, what's the point???? Soon as you get it off, it will be back in a week or so.
dougbfresh is offline   Reply With Quote
Old 01-01-2009, 02:49 PM   #4
rws.1
CF Senior Member
rws.1's Avatar
That is why many of us buy zinc dipped rotors...
Only the fire path gets exposed to rust and that is wiped clean every time you brake.
rws.1 is offline   Reply With Quote
Old 01-01-2009, 03:01 PM   #5
jrose7004
CF Senior Member
jrose7004's Avatar
Jim Rose Jim Rhttp://www.linkedin.com/profile/view?id=89789687&trk=hb_tab_pro_topose
Exactly!
jrose7004 is offline   Reply With Quote
Old 01-01-2009, 03:21 PM   #6
Mag Red C5
Junior Member
Default You're right.
Thanks for the info. I'm just overprotective. If it's not going to hurt anything, I may just leave it until spring. And I may use one of those green scotch pads suggested.
Thanks again for the info.
Old 01-01-2009, 03:25 PM   #7
Patman
CF Senior Member
Patman's Avatar
I've been trying to look for good deals on new rotors for my C5 and I see a lot of them mention that zinc chromate plating helps resist corrosion, but I've also heard that cadmium plating is even better, is this true?
I personally don't mind seeing rust on the surface of the rotor as I know it'll be gone when I drive it (and mine is a daily driver, so it doesn't sit for long) but it bugs me how my rotor hats and the fins of the rotors are so badly rusted!
__________________
Lemans Blue/Steel Gray 2005 coupe (M6)
NAV, F55, HUD, clear roof, polished wheels
Patman is offline   Reply With Quote
Old 01-01-2009, 03:26 PM   #8
slvrzo6
CF Senior Member
slvrzo6's Avatar
If this car is going to be sitting OUTSIDE with a Car cover don't worry about it. The Rust will come right back in a week or so.. If it's going to Sit inside, just drive around the block and put it in the garage.
slvrzo6 is offline   Reply With Quote
Old 01-01-2009, 03:37 PM   #9
Patches
CF Senior Member
Support Corvetteforum!
Patches's Avatar
Then there's the "extreme" method posted here in 2004 by none other than Evil-Twin himself:
"There are some tricks;
Here is what I do. Knowing that brake dust is a bit harsh and zinc is soft, and sooner or later the protection will fade.
once a year since two years ago, I have done this :
I only do two Rotors at a time, it is labor intensive. I remove the two front rotors, throughly clean them with brake cleaner, making sure I clean out the cooling vains, then blow them off.
I take a dremel tool and polish each hole with some 120 emery ( just a small square of emery 3/8ths sq. on a dremel arbor ) I polish each one to a mirror finish. IT takes about a minute to do one section of holes.
I made a tool from a paint stick which mimics the slot width and radius.
I use OO steel wool under the paint stick and rub it up and down the slot ( like trying to start a fire by rubbing a wooden stick ) the steel wool will remove any brake dust that is crusted into the slot and polish them. This all takes about a half hour. I then take a Q-tip and some 1500 F clear paint. I dab each hole with clear, allowing the clear to drip down inside the hole. I also do the slots. I let this dry and start the other rotor, after an hour or so working on rotor #2, I dab another coat of clear on the holes and the slots of rotor #1, after doing this to rotor #1 , I then do the second coat of rotor #2. It's now lunch time.. After an hour, I mask off the fire path ( where the pads contact the rotors. )
I then use steel wool on the outside edge of the rotors, and If you do not have two piece rotors with aluminum hats, you can steel wool your steel hats. then the last step is spraying the hats with clear 1500 F clear as well as the outside area vain area. let it dry for 30 minutes and apply a second coat. This should last the whole summer season. My rotors look like jewelry. "
And they always do. A shot of ET's clean machine. He is even more **** than I am.
Click the image to open in full size.
I keep mine clean but have yet to try his method. I pull my wheels at least once yearly and do a thorough wheel/tire/wheel well/brake cleaning.
Patches is online now   Reply With Quote
Old 01-01-2009, 04:52 PM   #10
moserbe
CF Senior Member
moserbe's Avatar
Now tell the truth, you have already gone out and cleaned the rust off, haven't you???
moserbe is offline   Reply With Quote
Old 01-01-2009, 07:04 PM   #11
Oldvetter
CF Senior Member
Oldvetter's Avatar
Wow, I never saw that post from ET, what a job!
I remember ET's wheel well "cleaning" procedure. I even got "ONE TOUCH" to use (but never got around to it).
But you have to admit, ET has one fine looking car !
Oldvetter is offline   Reply With Quote
Old 01-01-2009, 07:39 PM   #12
dobewillie
CF Senior Member
dobewillie's Avatar
a lot of work but great results patch
dobewillie is offline   Reply With Quote
Old 01-01-2009, 11:02 PM   #13
GMANS C5
CF Senior Member
GMANS C5's Avatar
I kept having the same problem so I painted my drilled slotted rotors with a quick coat of high temp black. The hats look great and no more rust!
before
after
GMANS C5 is offline   Reply With Quote
Old 01-02-2009, 07:08 AM   #14
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
The steel wool will work just fine. About the only way you're going to keep the rust off is to get zinc washed rotors or paint the hats on your existing ones (although the rust will still form on the pad surface until you drive it).
Vetteman Jack is offline   Reply With Quote
Old 01-04-2009, 05:10 PM   #15
Sky King
CF Senior Member
Sky King's Avatar
Send a message via AIM to Sky King
I'm just curious... is built up rust detrimental to the brake pads in any way?
Sky King is offline   Reply With Quote
Old 01-04-2009, 06:16 PM   #16
rebelheart
CF Senior Member
rebelheart's Avatar
While you all are sitting around cleaning brake rotors I am out driving and enjoying my vette!
rebelheart is offline   Reply With Quote
Old 01-04-2009, 06:18 PM   #17
Oldvetter
CF Senior Member
Oldvetter's Avatar
Quote:
No, the brake pads only touch the firepath. The rust can get on your wheels.
Old 01-04-2009, 08:00 PM   #18
tramminc
CF Senior Member
tramminc's Avatar
[/QUOTE]
How deep are those?
tramminc is offline   Reply With Quote
Old 01-04-2009, 11:38 PM   #19
mrgil
CF Senior Member
mrgil's Avatar
Quote:
before
after
I posted this before... go to a welding supply store and buy a rattle can of bright zinc paint, it works and stays on and looks good. I'll be doing my baer rotors again as soon as it warms up a little.
mrgil
mrgil is offline   Reply With Quote
Old 01-04-2009, 11:41 PM   #20
dachevy
CF Senior Member
dachevy's Avatar
Quote:
Painted mine red over the summer...no rust here., and this weather is crazy, freezing, then warms up then cold...go figure..
dachevy is offline   Reply With Quote
Reload this Page Removing Rust from Rotors
Tags
brake, c5, clean, cleaning, corvette, cover, remiving, remove, removing, rotor, rotors, rust, rusty, steel, wool
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rusty OEM rotors...my little project to attack this subject>>> C6FirstVette C6 Tech/Performance 20 12-04-2013 11:02 AM
Brake Rotor Change Directions - Self Install or Dealer? c6am C6 Corvette General Discussion 24 08-30-2005 02:46 PM
Removing rear brake rotors? Bolts are STUCK! Tony @ MPH C5 Tech 15 02-01-2005 11:55 PM
Removing 35 year old brake rotors. Steve Straus C3 Tech/Performance 9 02-01-2004 10:50 AM
Any Tips For Removing Rust From Rotors? CG77VETTE C4 General Discussion 23 05-31-2003 05:00 PM
Is there a rust conversion chemical to put on Rotors????? chuckster C5 Tech 21 10-01-2001 12:48 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
