Best Bang for my Buck??
I have an 03 c5...Only Vararam intake (which i love)....without dumping a ton of money into it right away, what is the best way to get the most power out of it??
any inputs would be appreciated!!
Money wise, right away under $2000
Last edited by Scoops03; 12-20-2008 at 12:25 PM. Reason: Clarification on $ wanting to spend
In my quest of power mods without compromising fuel economy I vote for a rear diff ratio change. Us MN6 guys do a 4.10 (stock is 3.42), the A4 folks go either 3.42 or 3.73 an increase over the stock 2.73 or 3.15 performance axle. Do a search on this and read all the positive feedback.
Received 19,359 Likes
'20-'21-'22-'23-'24
The gears will give you quicker acceleration for sure. For added power, a good set of LT headers would give you a boost. Not sure what amount you have in mind, but heads/cam are nice too.
A ton of money means something different to everybody.
Gears are a great idea, but I always thought that doing both the gears and a converter (providing its an A4) at the same time made a lot more sense.
I would say just get a good tune if you don't want to spend a lot of $.
Guess I'll be the second to say nitrous Nothing else will give you the HP for $$$ impact. I do a fair amount of highway driving, so I passed on the 4:10 change-out.
St. Jude Donor '05-'06-'08
$500 to $1000+ for nitrous. Add 1/3 more rear wheel HP from stock with a simple 125 shot. Installed over a weekend with the help of a few good (and knowledgeable) friends I met on this forum
$2k would almost get you the heads you'd want to make bigger power. Probably get you a cam/timing chain and more.
Heads/cam/headers would get you to maybe 440-465 rwhp. If you are ok with used, you can sure find some deals right now (people de-modding, etc). About $5k for new top quality parts (Trickflow/AFR/etc). I've seen nice heads/cam packages go much cheaper lightly used.
St. Jude Donor '09
Horsepower without spending a lot of money does not equate. But ya the cheapest method is the bottle for sure. My experience though and I am sure everyone will back me up here...it never stops there
St. Jude Donor '09
If you pay someone to do the work....
Gears + Stall = 2000 + And stall only serves its purpose when you stomp it..
Heads,Cam,Headers,Tune and misc parts = 4,000
If its An auto slap a set of 373 gears and be happy, If its an auto with h/c header pakage with no stall youll get about 400 hp @ the wheels not
440 or 460
440 or 460
