Does Seafoam really work???
OK, so people have been talking about this stuff like its the second coming or something!
Since you fine folks in this forum are extremely knowledgeable about C5's, i'd really like to know if this stuff would really work to clean out the carbon buildup in my Z without any consequences whatsoever.
Thanks again for your input, and looking forward to the responses!!
Thanks Ryan.
I'm still pretty skeptical of this stuff.....I mean, how many corvette owners have seen the excellent results claimed firsthand after using it? I'm one of those people who doesnt believe of a 'fix it in a can', so I am very very hesitant to put this stuff into my baby.
Also, what will the long term affects be? Is it safe for the gaskets, engine internals, and O2 sensors? $6.99 to clean the entire top end of my engine just doesnt sound right to me at all......
seafoam, has been around a looong time. i used it in the late eightys in boats because the price was a lot cheaper than stabil. it got popular when napa started selling it and took off from there. i still use it in my boats for storage and also my vette when stored without any problems what so ever. my friends with small block cars who have vapor lock issues like it too. as far as injector cars, i don't see how it would hurt anything. actually the manufacturer who recommended it to me years ago was mercruiser....good luck
It's not really a 'Corvette thing.' Seafoam has been around for years and a Corvette has a combustion engine, just like everything else. I use it on all my vehicles every 25k miles or so with great results (trucks, cars, whatever.) It cheaper to use an $8 can of Seafoam than paying a lube shop $50 to do the same thing.
OK, so the next logical question is: where the heck do I put it in?
Thank you for ALL of your input, gents! I really love this forum and all of the knowledge you folks share!
St. Jude Donor '10
I agree with adding it to the fuel every so often but I wonder about using it through the vacuum lines to clean out oil build up in the throttle body and intake caused from the PCV. Has anyone ever used this method and then opened up the throttle body and intake to see if it was actually cleaned? Sure there is a ton of white smoke coming out the exhaust but that doesn't really prove anything has actually been cleaned.
I have used SeaFoam for the last 10 -15 years, I add a can to a full tank of gas for my vehicles. For my mowers etc. I use about 1/3 can per my 6 gal gas cans.
Several years ago, I purchased a used '88 Cutlass from my folks, for Dad had purchased a new Buick. Car was little sluggish so I put on new plugs / wires, etc ........ improved but not as good as I hoped. Then thinking maybe it had some dirty injectors ...... I put in 2 cans of Seafoam and ran it through a tank of gas ...... made a difference.
You can hook it up to one fo the vacuum lines (I haven't done it) and run it straight ..... your exhaust will smoke to beat h-ll, direct injector cleaning. It does work
Use it as part of your maintenance schedule.
I don't doubt that it is an effective fuel system cleaner, but I am skeptical about removal of carbon from combustion chambers. I pulled my heads to replace cam and lifters and soaked the combustion chambers in seafoam for about a half hour. It had minimal effect on stripping the carbon until I used a wire brush.
Corvette C5 Enthusiast
i have fed it through the vacuum lines off my cars for years. If it has never been done and the car has 50k+ miles on it you will fee a difference. find a vacuum line as close to the tb as possible. its best to have help on this as you need someone in the car to keep the throttle at 2k rpm or so so it doesnt die. stick the line in the SF or use a funnel and slowly administer the SF until 1/2 can is gone. while you are feeding it into the engine and reach this half way point have your friend in the car kill the engine while it is still sucking it up until the motor stops. it may diesel for a few seconds. thats ok.
Let is sit for about 1-2 hours like this (engine stopped). Start it up after in a well ventilated area and get ready for a show. Your exhaust will smoke like a freight train. Your neighbors will think you are totally insane.
When you start it up rev it up. i get the best results when i vary rpm after start up.
Problems: if you currently have a very large amount of carbon build up the seafoam will wash a lot of it away, but if you have cats it may stop there possibly choking the cats up. If you have long tubes and cats just unbolt the x pipe and run straight headers. If the smoke alone wont get attention i am sure this will help!
Wow! This is excellent news to see quite a few of you having great experiences with it.
I truly do appreciate each and every one of your opinions on this!!
I'll be buying myself a can today!
Yep, the neighbors are going to LOVE me doing this.
1 Post
St. Jude Donor '09
This thread was the first I've heard of Seafoam, and it took me 10 seconds to find this:
http://www.seafoamsales.com/motorTuneUpTechGas.htm
