Do jacking pucks stay on the car?
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Disregard....found it on another thread....
Part # 51 71 1 960 752
Item is called: Jacking pad- 2003 or 2004 325ci
$6.95 each from www.bavauto.com
Received 19,440 Likes
'20-'21-'22-'23-'24
If you get a set like the BMW ones, then yes, they can stay on the car all the time. Otherwise, for the other styles it would probably be best to only put them on the car when you need to jack the car up.
I would not use the plastic ones that snap in. They tend to break if you really use them much.
I would go with metal pucks for safety because they do not deform or break.
You do not say what type of pucks you have, but most pucks that are sold fit loosely in the frame rails and it is obvious they are not meant to be left on the car. The GM ones even come with little chains attached just so they are visible from the side and are not accidentally left in.
