A4 guys-do you drive in "D"
I keep mine in drive all the time. Mine doesn't do frequent shifting back and forth, but part of the reason for that is that in my tuning I had him disable the torque converter lock up function in 3rd gear. So my converter will only lock up in 4th now. I also had my 3-4 part throttle shift point raised too, so instead of shifting into 4th at the stock setting which was around 42 or 43 mph (which would lug the motor too much), under most throttle positions now it won't shift into 4th until closer to 48 or 49 mph. Makes a big difference in driveability that's for sure!
In the mid 90's we use to go thru a lot of transmissions in our squad cars ........... I talked to a GM transmission trouble shooter and he told me if we were in areas where the trans was to shift alot going thru different speeds .......... leave it in 3rd until oh highway maintaining higher speeds .......... haven't rebuild a tranny since.
In town driving .......... I'm in 3rd.
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Since putting on the Corsas I now drive in 3 just to hear the awesome exhaust note...can you say "sweet"?
I keep mine in D most of the time. I'll shift it into 3rd if I'm going down a long, steep hill and don't want it to gain momentum and exceed the legal limit in case a cop is sitting at the bottom. It beats riding the brake all the way down. There are other circumstances, but that would be the most common.
