Royal Purple vs. Amsoil
They're both high quality synthetics.
But then again.... anytime you ask about oil - there's always heated debate (atleast on most auto enthusiast forums I've been on). So sit back and watch the show....
We're running Amsoil in our diff & tranny.
St. Jude Donor '06
1 Post
St. Jude Donor '06-'07
AMSOIL Synthetic 10W-30 Motor Oil is recommended for use in gasoline engines and other applications requiring any of the listed worldwide specifications:
API SM/CF, SL, SJ ...
ILSAC GF-4, 3 ...
ACEA A5/B5
JASO VTW
GM 4718M, 6094M
Ford WSS-M2C205-A
Daimler Chrysler MS-6395N
VW 503.00
Within the last 6 months someone also posted an extensive test comparing the wear or lubrication property's for many of the major brands of motor oils. If someone has the link please post it, it was very informative.
By the way, I use all Royle Purple Fluids in my Z06....
[QUOTE=BobbyG;1560425788]AMSOIL 10W-30 does meet GM engine oil specifications and is one of the best oils available today.
ILSAC GF-4, 3 ...
ACEA A5/B5
JASO VTW
GM 4718M, 6094M
Ford WSS-M2C205-A
VW 503.00
Amsoil is the only oil for me. I run it in all 3 of my vettes, in my Hummer and in the Harley. I use the 7500 oil in the cars & Hummer.
ILSAC GF-4, 3 ...
ACEA A5/B5
JASO VTW
GM 4718M, 6094M
Ford WSS-M2C205-A
VW 503.00
Once you start comparing top-tier synthetical oils, I think the debate becomes moot. My advice: use any of the top synthetical oils (Mobile 1 certainly is a safe choice), change it regularly as recommended or appropriate to your circumstances, and quit over-thinking it.
Cody1112, if you want to find out more about different oils then read a couple of threads on this site.
http://theoildrop.server101.com/foru....php?Cat=0&C=2
I read somewhere that the molybdenum in royal purple acted as a great lubricant with a strong barrier but at the same time caused excessive wear. Anyone have any experience with excessive wear from royal purple?
St. Jude Donor '11
