[Z06] rpm gauge on 2004 z06 not working
my friends 04 z06 rpm gauge shuts down and turns back on when u go over bumps. does anyone know whats going on
I'll hook it up to some kinda datalogger to see if the pcm is loosing a rpm signal also. I find it weird that just the tach will cut out and nothing else on the cluster. just making me believe its not the cluster connection.
Again, there is a ground on the side of the engine block just below the #6/8 cylinders that may be loose. This usually affects more than just the tachometer though so maybe the cluster is going bad????? Any codes related to the IPC?
