Escort 9500ix In Stock
Old 07-04-2009, 02:34 PM
  #41
JustinStrife
JustinStrife's Avatar
Wish I had the money right now to get one. Going on a coast to coast trip this fall in the C5 and would be nice to have added protection. Better start saving my pennies.
Old 07-08-2009, 05:10 PM
  #42
Git Er Dun
Git Er Dun's Avatar
I have never owned a radar detector before but really looking at this deal. I have a few questions though. With this new GPS tracking and stuff where it marks places where you always get a signal so that after 3 times it is supposed to not trigger "false" alarms anymore. What if the police constantly use the same pull out or place to do radar...after 3 times wouldn't the detector think it was a false alarm and automatically make it so that the detector would no longer trigger an alarm there...so that 4th or 5th time going past that pullout where the cops were doing lazer or radar it would no longer alert you? This is the main thing I am worried about with this intelligent detector thinking that it's not a speed trap when it really is.
Also I am kind of confused on the invisicord thing...Do you just unplug a wire from the back of your rear view mirror or something to power it so that you don't have a cord running down to a cigarette plug? Is there a thread with an instal with pictures of how the invisicord works that anyone knows of? The car it would be going in is a 99 Fixed Roof Coupe. Do you recommend the 8" or 12" cord for that car?
Thanks for any input. -Eric
Old 07-08-2009, 05:41 PM
  #43
Git Er Dun
Git Er Dun's Avatar
Opps I guess I should have done more research on it before posting. It looks like you can hit a "mark" button for known radar areas where you know they sit so it gives you a little beep warning that you are coming up on the area. What if it's an area with a lot of false alarms and then the cops set up a trap there...the system should alert you then because the radar and laser guns have a different frequency?
Also it looks like the invisicord should work on my 99 just fine. I am just getting back from a deployment to Iraq though and have never seen my FRC and don't know if the mirror has the plug and play invisicord capability...Do all 99 FRC have a powered rear view mirror or was it optional?
How far can this detector detect on average? What is the range of the V1 or the competition?
Old 07-09-2009, 09:00 AM
  #44
southerncarparts
Supporting Vendor
southerncarparts's Avatar
St. Jude Donor '06-'07, '13, '15
Originally Posted by Git Er Dun
Opps I guess I should have done more research on it before posting. It looks like you can hit a "mark" button for known radar areas where you know they sit so it gives you a little beep warning that you are coming up on the area. What if it's an area with a lot of false alarms and then the cops set up a trap there...the system should alert you then because the radar and laser guns have a different frequency? Correct......
Also it looks like the invisicord should work on my 99 just fine. I am just getting back from a deployment to Iraq though and have never seen my FRC and don't know if the mirror has the plug and play invisicord capability...Do all 99 FRC have a powered rear view mirror or was it optional? I think they all do...
Seems to be about a mile or so....I tested both the V1 and the Escort side by side, range was about identical....
See ya,
jim
Old 07-09-2009, 09:11 AM
  #45
COCONUTS
COCONUTS's Avatar
Isn't this "Power Plug" in the mirror C6 only?
I have a C5 and have never seen this plug.
I'll have to look at my mirror again carefully.
Old 07-09-2009, 10:29 PM
  #46
southerncarparts
Supporting Vendor
Take a look.....I think it it there...
Jim
Old 07-22-2009, 10:59 PM
  #47
intoc6s
intoc6s's Avatar
I have this one in the Vette and i have a Valentine 1 in my Crown Vic, HANDS DOWN, This one is a BETTER Radar Detector! I have BOTH, and I like this one best! When i bought this one i was looking for the BEST one i could buy, And i got it! - Jason
Old 07-23-2009, 10:58 PM
  #48
southerncarparts
Supporting Vendor
Thanks for the post....I agree with you 100%. V1 is good, but does not stand a chance against the 9500 IX
Thanks,
Jim
Old 07-24-2009, 11:42 AM
  #49
The Spark
The Spark's Avatar
Just ordered one.
A friend swears by his V1 and the arrows. We're going on the '09 Caravan so we'll see how they compare.
I do like the idea of knowing which way the radar is - but really does it matter. If you're getting hit by radar aren't you going to slow down anyway?
The only way I could see that it helps you if the radar is behind is that you can speed up when they aren't hitting you (ie, around a curve, over a hill, blocked by 18-wheeler) to try and get some distance. I had a book years ago with tips to avoid speeding tickets. One was to speed up when you were blocked from following radar and then slow down when they were in sight.
BTW - best deal I've found on the 9500ix with all the accessories.
Thanks.
Old 07-24-2009, 04:42 PM
  #50
MyBlueC5
Support Corvetteforum!
MyBlueC5's Avatar
St. Jude Donor '05
CI VI Veteran
Don't you guys give discounts to forum members? No offense but at 499.00, I can order anywhere and get that price...
I may be wrong but I would have thought there would have been a discount to to forum members that joe blow off the street.
Mark
Old 07-24-2009, 07:08 PM
  #51
southerncarparts
Supporting Vendor
Mark
Checkout the link in this post....You will see that there is much more to what we are giving you than what anyone gets off the street.
For 499.99, at any other place, all you get it the radar detector.
Take a look and then shop around....you will see what I mean.
See ya,
Jim
Old 08-02-2009, 11:59 AM
  #52
ZR1991
ZR1991's Avatar
To confirm, the mirror mount does not work on the C5, but the invisicord does?
Old 08-02-2009, 05:12 PM
  #53
southerncarparts
Supporting Vendor
We do not offer a mirror mount...I think you might be confusing it with the C6 Visor Mount. The C6 Visor Mount does not work on the C5 but the SCP Super Suction mount does. The invisicord also works on the C5.
Thanks,
Jim
Old 08-02-2009, 07:04 PM
  #54
ZR1991
ZR1991's Avatar
Thanks, you are correct.
Old 08-02-2009, 11:08 PM
  #55
Whaler21
Whaler21's Avatar
When watching the youtube link http://www.youtube.com/watch?v=yvCvJ8IrD1A twice the guy stated this unit picks up all radar and laser used today. I have been reading that no detector picks up layser... true? Is this guy wrong or will this save me from laser?
Originally Posted by southerncarparts
New Package Deal!!!!
The long awaited Escort 9500ix is finally in stock....
This is the absolute BEST Escort 9500 IX deal you will find anywhere. We are the only Escort dealer offering a complete Escort 9500ix package with EVERYTHING you need to take full advantage of the 9500 IX's full capabilities. For one price ($499.99+shipping) you get the USB Cord (to connect the Escort 9500 IX to your computer, not normally included with the detector), an AC to 12vDC lighter socket adapter (which allows you to use a regular AC wall socket to power the Escort when connected to your computer. Again not normally included with the detector), the incredibly popular SCP Super Suction Mount (for use on any car) or the Corvette C6 Visor Mount, and the 8" or 12" Invisicord (to connect the Escort to your powered rear view mirror).
This is Escorts latest GPS Radar detector that LEARNS and blocks out false alarms. Also is programmed with all known speeding cameras.
Click below for more details (including a demonstration video on how the 9500 uses GPS to block out false alarms)and ordering info...
Escort 9500 IX
Want a second opinion, see what Popular Mechanics has to say about it...
http://www.popularmechanics.com/blog...s/4279971.html
Watch the demo for more info...
Thanks,
Jim
Old 08-03-2009, 02:42 AM
  #56
drew47000000
drew47000000's Avatar
Wouldn't using the inviscord and visor mount mean that you have to forgo the luxury of the mini remote. I'm not sure what its called but its the little remote where you can control a couple different things like muting and something else. I think its 2 buttons on the cig lighter if you know what I mean?
Old 08-03-2009, 02:46 AM
  #57
drew47000000
Mark
Hate to say it, but you can snag one of these for around 425 brand new shipped any day of the week via ebay. I dont think it has the extra's though, but cant you just use the usb wire from your printer when you need it. Also how much is the inviscord when sold separately (arm, leg, or both?)
To Escort 9500ix In Stock
Old 08-03-2009, 04:26 PM
  #58
southerncarparts
Supporting Vendor
Obviously you do not hate to say it that much ....
You can try it if you wish, but risky. Escort has had huge issues with people selling them on ebay...Units that are stolen, modified serial numbers, 9500 I's in and IX case. 8500 internals in an I, or IX case....
If you buy one one at a non Escort dealer, it is at your own risk. Call Escort and ask them about this.
See ya,
Jim
Old 08-03-2009, 04:27 PM
  #59
southerncarparts
Supporting Vendor
It is built into the curly cord...yes, if you use the invisi-cord then the curly cord/remote would not be used....
We give you both, so you can decide to hook it up however you want...
Old 08-04-2009, 07:12 PM
  #60
drew47000000
Ok I gotcha. What functions are on the remote again? And these can be utilized on the detector itself correct? Also I would be happy to purchase one from you for the ebay price point. I'd imagine those guys are still making money even at that price or else they wouldnt be doing it. With the economy in this state we all really need to watch the pennies. I hope this sounds reasonable.
Quick Reply: Escort 9500ix In Stock
