Attempt at a "show sign"
I think this one does the job finely!
i think the new one is how i would do it. have you tried the txt in white? and if its too light try darking the ground behind the words to make them pop.
also what font is "radioflyer" in??
Cruise-In 9-10-11 Veteran
St. Jude Donor '08-'09-'10,-'13
I believe in the Beer Fairy
That's a lot of text......otherwise, I think it looks nice.
St. Jude Donor '05-'06-'08
"Radioflyer's 1997 Coupe" is difficult to read. First rule of a sign: it needs to be readable.
Perhaps instead of the dark shadow . . . a blurred one.
Bigger letters would also help.
Craig
Craig
St. Jude Donor '12
FYI - The laptop will likely be hard to see in the sunlight. Also, it will have people leaning into your trunk to get a better look. No big deal if you aren't **** about that.
My last show sign had lots of text like yours. I'm still thinking through a redo to eliminate most of the text and hit a few highpoints. I had always hoped people would read the sign, but only a few did at each show.
I'll be at the SHCC and COCH shows. Hope to see you out there.
chris
chris
#33
Former Vendor
St. Jude Donor '08
chris
chris
#34
I like the sign with the larger text.. but.. at a show, I would get bored about 1/2 to 3/4 way through and not read the whole sign anyway. If I can't read it from a little distance, I'm probably going to be standing in the way of others trying to get a peek to read the whole thing.
If you can cut back on some of the text it may be better.
It is a cool looking sign, though.
#36
#37
Man that looks way better!!!
signguy........
The forum "signguy" ......
Here is his site. He is a forum vendor........
http://www.motorheadbanners.com/
signguy........
#39
St. Jude Donor '12
http://forums.corvetteforum.com/show....php?t=2114077
It will be in Pearland at the new Town Center. Date has been changed to 11/15.
Hope to see you there!
chris
