[Z06] HELP! Installed Halltech Intake and at track check engine light comes on.
It has done it twice at the track and the first time the code was lean condition bank one and the second time was lean condition bank two. I checked all the fitments and there is no air leaking, the seals are tight, there is no oil residue on the intake. Anyone else have this problem? It doesn't come on during daily driving, only at the track. I have lost almost 2mph. The car is completely stock other than the Halltech and DR's. Any help would be appreciated.
It is not unusual to see lean codes with 3rd party intake systems.
The new intake changes the way air flows through the MAF, which can change the volume of air reported by the MAF to the PCM. Another example of this is people who de-screened their MAF. Many who de-screened got lean codes also.
The amount of air hasn't changed, but the amount reported has changed.
You will either need to get the PCM "tuned" so that the MAF table in the PCM reflects the altered airflow, or re-install your stock system.
Received 1,506 Likes
No-IL Events Coordinator
C6 of Year Winner (appearance mods) 2019
2018 C6 of Year Finalist
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I thought relocating the MAF sensor to the front of the throttle body was suppose to prevent this???
262-965-4300
info@halltechsystems.com
262-965-4300
262-965-4300
262-965-4300
starting with the relocation the Delphi 85 MAF sensor to the rear of the intake bridge for better MAF sensor readings less chance of lean codes
http://www.halltechsystems.com/Produ...ductCode=V1025
Note ... LESS CHANCE ..... not that it can't still happen.
The MAF is a very sensitive measuring device ..... messing with it can throw it off .... want proof ???? Compare the MAF tables from a Pontiac GTO with the LS6 and the same tables from a Corvette with the LS6 ..... they're different ..... WHY ???? The two cars have different intake "plumbing" because of the different engine bay sizes ..... so GM had to "tune" the MAF table for the GTO because while all else is the same on the two engines the plumbing change affected the MAF readings.
1 Post
I looked up those codes in my service manuals and the problem is in the O2 sensors indicate a lean condition. It states a lean condition could be present during high fuel demand due to a fuel pump that does not pump enough fuel. Note leaks around the intake manifold, throttle body, and injector O-rings. Need to get a tuner to run diagnostics on it. May not be that bad!
