C6 Z06 brake conversion w/ Goodridge SS lines <<PICS>>
Well, it's been 2 weeks since I got my C6 Z06 brake set up and finally I had some time today to do the swap (wife helped bleeding them! ). Now the brake calipers fill the wheels quite nicely!!!!
Some shots of the brake calipers and the pads.
My C6 Z51 set up.
The calipers just bolt right up to the spindle.
Comparison between C6 Z06 and C6 Z51 rotors.
I had to modify the fitting (cut the fitting on a 45* angle) so the line wouldn't be right next to the lower caliper bolt.
Caliper mounted and bled!
Fronts are done!
Rear calipers and pads
C6 Z51 set up.
Remove the calipers and brackets.
This is the stock fitting for the C5 rear caliper and Goodridge lines.
Picture of a stock C6 Z06 caliper and the stock brake hose fitting.
C5 parking brake shoes are the same so no need to do anything other than adjust them while you have the rotors off.
The calipers mount to the spindle just like the front.
The C5 mounting bolts bolt to the threaded calipers on the C6 Z06 calipers.
Comparison shot of the rear rotors. The Z06 rotors are slightly larger in diameter but the swept area is much larger.
Mounting the lines like this will interfere with the lower mounting bolt.
I modified the end to fit perpendicular to the caliper
Mounted the caliper and ready to bleed it.
My dual bleeding apparatus.
My C6 Z51 set up.
Fronts are done!
C6 Z51 set up.
LOL. I thought they were about the same size too but seeing them side by side, you can tell the Z06 rotors are slightly bigger. But the added benefit would be the Z06 rotors are much thicker and beefier, especially the rear rotors!!!
Nice writeup! I did that mod last year and it is a big improvement over stock!
Looks great, good job and nice write up. I need to get me some of them bad boys for my 04.
Received 19,284 Likes
'20-'21-'22-'23-'24
Very . The new setup looks awesome.
Former Vendor
1 Post
Looking good Rick!!!!!! I want to do them on my car, especially after driving John Bourg's car and feeling first hand how much of an improvement they are over the stock setup!!!!!!
Those look great, very nice. Thanks for the pics and the write-up. Those are my next mod for sure. Have any pulled back pics of your car with the new brakes?
Where did you get the kit from? And if you could PM the price that would be awesome as well. Thanks!
Uber Waxer
that looks great rick! if I hadnt spent so much on eradispeed 2 piece rotors and powdercoating stock calipers, i would have to do this mod.
