Z06 Top Speed
Received 1,511 Likes
No-IL Events Coordinator
C6 of Year Winner (appearance mods) 2019
2018 C6 of Year Finalist
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
275.2 kph sounds better.
You guys are breaking my heart. I have both the 2.73 gears and the 300 kph cluster (bought more for the ease of installing the HUD than anything else). Obviously I suck. At least it is a coupe.
Chris
Chris
Actually, the top speed of 171 mph for the ZO6 and 175 mph for the coupe are simply based on what speed each car is travelling while redlining in 5th gear (6th gear being too tall to reach top speed). While the Coupe is slightly more aerodynamic (.29 cd versus .31 for the ZO6) it has no bearing on top speed in this case.
Coupe - 5th gear @ .74 - 6200 rpm rev limiter = 191.25 mph
Z06 - 5th gear @ .84 - 6600 rpm rev limiter= 182.29 mph
EDIT: tried this at a couple calculator sites, they were within 1-3mph for some reason, still the point is the same.
Obviously both these speeds are without wind resistance and beyond both model's advertised top speed. So they are not redlining in 5th gear. A .02 cd improvement at 170+mph will certainly have a bearing on top speed.
