Show me how u store ur Targa top.
I want to hang the top on the garage wall. I have seen some holders on Ecklers and some of the other vendors.
Show me how or what you are using.
Ray
Ray
Moderator
Received 3,621 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
I'd be interested in this too. I have both tops and no room to store them
St. Jude Donor '05-'06-'08
Moderator
Events Coordinator
http://www.ecklers.com/product.asp?p...0&dept_id=1400
Moderator
Events Coordinator
Mine is in the Guest room at the BF"s house. Didnt know if it is OK to store it "flat" and if so which side should face up?
I store mine under the guest bed as well, resting on the top (outside part). That way it won't compress the weatherstrip pieces on the edges and corners.
Moderator
Events Coordinator
Here's a rack that meets all Redneck Engineering guidelines: Cheap, efficient and ugly! It is out of sight in a storage room, and works great.
Cut a 2x4 with a contour slightly smaller than the rear of the top. Drill two holes for the roof rear studs. Cover with cheap felt.
Screw on wall. A velcro loop pad will keep it from touching the wall and a bungee strap secures it. The studs support the steel frame so it is in no strain and the weatherstrip isn't deformed.
It's not pretty but it has worked well for several years.
St. Jude Donor '08
