Help!! Overfilled oil
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
Had the oil changed and it is 1/2 qt over. 7qts instead of 6.5qts.
Is this ok or should I drain out 1/2 qt?
Thanks.
Thanks.
Cruise-In VI Veteran
7 quarts is OK Should not hurt a thing. Most guys run 7 anyway.
Just paid 4.56 a quart at Wally world by the way.
Bought the 5 quart jugs (5 30 Mobile) for 22.80 a jug.
Hi Big-Red -
Like Benpup said - just fine.
best regards-
mqqn
best regards-
mqqn
Location: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
1/2 quart? Rest easy,you're okay
There was a post the other day......... Autozone has a sale with 5 quarts of Mobil 1 and a Mobil 1 filter for 26.00. I picked up two yesterday, might go back tomorrow for more . David
OOPS! forgot, 7 quarts are just fine.
7qts is completely safe, I run 7qts in mine all the time. And I used to run 7L when I was using Castrol, that converts out to 7.5qts. Not only that, but when I change my oil I don't bother with the hassle of raising the rear, so I've got about an extra 1/4 to 1/2 of a quart in the engine just from not doing that.
So you're completely safe, these engines can handle a lot of extra oil before you run into problems.
