Hi guy's , newbee 03 Z06 . i had a bird dropping on the hood (1/2"dia.)
it was there 24 hours. it left a stain even after washing. i tried a clay bar
it's still there. this car has a beautiful finish on ,it garaged ,11K miles, it's babied. How do i remove this spot? it looks like it eat through the clear coat. the car color is torch red.
Yep, this has been discussed any number of times in the Car Care Discussion section of the Forum. Too, several very knowledgeable people and few professional detailers hang out in that section and they may be the ones that can best help you with this topic.
do you have a link for White polishing comp & or different grades of clay bar?
thanks
Forget the claybar, that will remove any bird droppings left on the paint, but will not remove the stain. Go straight to Polishing compound. You can pick it up at any local pepboys, autozone, etc. Hit it with a damp MF cloth and follow it with what ever wax you use. You may have to repeat the polish process till it's completely out, but it's a sure fix.
The clear coat is much thicker than your red base coat.The bird dropping probably only etched the top surface of your clear finish.
Rub out the area with WHITE polishing compound on a dampened piece of terry cloth.Then apply your favorite polish or wax over the area.
__________________ ROADAPPLE Life is not a journey to the grave with the intention of arriving safely, and in one handsome and well-preserved piece.
You should slide broadside across the finish line, thoroughly used up, worn out, leaking oil, and shouting "Geronimo!"
sorry to break it to you, but c5 clearcoar is very hard, its very doubtful that you will remove any etching from the finish by hand unless you work on that same spot for a very very long time.
a professional with a rotary could probably fix that 1 spot in less than an hour.
__________________
Brian Rice
04 MY C5 Vert A4
62 C1 Vert 327/300 4 speed
2006 Silverado 2500HD CCSB LLY/Allison
Mine is gone now
It took a year and a half
Peace
Chip
__________________
....................................Follow Us
..............."Killing the Corvette Tax One Product at a Time"
Damned birds! There oughta be a law
I've had the same problem with anything that sits outside for more than ten minutes. My wifey feeds the damned things and they show their appreciation by leaving deposits on my rigs
I use Meguiar's Cleaner Wax and a bunch of elbow grease. It gits-r-done
I have always removed these stains with my normal wax.As long as the wax has some abrasive in it,repeated polishing will gradually get the stain out of the clearcoat.
