Sunroof cut into painted top?
Anyone see or know of anyone cutting and installing a sunroof onto a painted top? Interested in one that just cranked open a bit on the rear edge. Guess I'm just getting lazy since I won't stop and remove the top
Night Owl for life
Received 3,256 Likes
that might be an idea for an FRC, but for a targa car it's pretty much
St. Jude Donor '08-'09
I would think the small size of the top area would make it impractical. and too, by the surface of the top being contoured and not flat it would be difficult to find a unit to fit. any mechanism used to operate the unit would intrude into the cockpit's already cramped area.
just take the 45 seconds to remove the top and preserve the integrity of the design
Couldn't you just cut the pattern out of a clear top and fit it in. It seems that it would be the easiest way to match the contours. The hardest part would be to find and attach the mechanism to lift the back. As long as the frame of the top is intact, the rigidity of the frame should be fine. Seems like alot of work though when you could either get the clear top or stop and pop off the painted one, but that is just my two cents.
Good luck.
Chris
Good luck.
Chris
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Good luck.
Chris
Good luck.
Chris
I was thinking about this a while back. I agree it wouldnt be very practical but it may look cool with the c5 lines. Id like to see one too
Received 1,680 Likes
Hey Rhys, I know a guy that put a sunroof on his FRC!
I like the idea of some kind of easily removable top while driving. I'll throw some support behind the idea; way too easy to just say bad idea, why don't you just pull over, etc.. He was asking for some constructive comments.
I was thinking of possibly using the stock top, cut a large area out of it and then make some kind of a seal around it and a latch that would hold the removable piece in. Would take some engineering but possible and would make a salable product. The panel would be very light weight. Could reach up and remove it and put it in the back even while driving. When in it would look stock from the outside. Maybe use a sunroof mechanism and use the cut stock panel for the panel? Wouldn't leak if done right.
Take a look at the removable tops in the old Mazda Rx7s. They flipped up at the rear or could be removed. They did not slide back. I recall some people had glass tops as well.
The original Rx7 removable top was not that big and might fit w/in the parameters of the Vet roof. That would be a lot of work though. But then you could start selling kits. Make sure you send me my 20% cut of the gross income you make.
I was thinking along the same lines. I would really like a moon roof instead of the targa top. I almost never have the moon roof closed in my other cars but I've only taken the targa top off the corvette twice.
My '98 Acura GSR had a very small moon roof that powered up and back out on top of the roof. It was a very low roof with almost no headliner. It's small size would fit perfectly in a targa top. You would lose the double hump. Something to think about over the winter.
I'd like one for my convertible. I'm feeling lazy too.
