What is best way to clean crud off the inner barrels on aluminum wheels?
Old 04-21-2008, 08:18 PM
$$$frumnuttin'
$$$frumnuttin''s Avatar
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Default What is best way to clean crud off the inner barrels on aluminum wheels?
I thought I would clean up the inside surface of my Iforged wheels before putting them back on for the summer. I tried pressure washing them, but that didn't work. I will need to scrub them with something but I am not sure what to use...I don't want to risk chemically attacking the raw aluminum on the wheel face. Anyone encounter this problem before? The crud is some sort of baked on tenacious crap from years of service. Aluminum wheel cleaner does not remove it at all.
$$$frumnuttin' is offline
Old 04-21-2008, 08:38 PM
BADMFR
BADMFR's Avatar
St. Jude Donor '08
the blue non scratch scotch brite pads work great
BADMFR is offline
Old 04-21-2008, 08:57 PM
rcs128
rcs128's Avatar
I had some success using rubbing compound and a mother's powerball to clean the stuff off some wheels for my Audi (not sure if the surface is the same as your wheels). Still took a lot of time and elbow grease in the detail areas.
rcs128 is offline
Old 04-21-2008, 09:02 PM
BOTYNV1
BOTYNV1's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I clean mine while on the car . I use a product called All Sol made by Car-Brite, it will take off almost anything that shouldn't be there. Then re-wash wheels again , dry then apply a good dose of Metal polish or even plain old Sparkle(glass cleaner), then hit with a wax so cleaning next time will be easier. Just what I do, but it seems very effective
BOTYNV1 is offline
yaknow
yaknow's Avatar
I used simple green and a nylon scrub brush to get the top layers of crud off my old c4 wheels, then followed up with bug and tar remover.
yaknow is offline
Old 04-22-2008, 12:34 PM
$$$frumnuttin'
thanks guys, now you know I am talking about the INSIDE surfaces....what you can see through the spoke openings. Not sure how anyone could clean that area while the wheels are still on the car, but I suppose anything is possible with the right tools.
Old 04-22-2008, 12:38 PM
WKMCD
WKMCD's Avatar
Have your wife do it....
Honey, you're not reading this are you?
I guess you were.
WKMCD is offline
Old 04-22-2008, 12:39 PM
10U 99
Support Corvetteforum!
10U 99's Avatar
St. Jude Donor '08-'09
0000 steel wool. if they are real cruddy use 00 first.
0000 = super fine. works great on raw aluminum, not polished or coated. gonna require a little effort. Lowes should have it in the paint dept
10U 99 is offline
Old 04-23-2008, 09:23 PM
$$$frumnuttin'
Had not thought of that...good suggestion. BTW, cool avatar
Old 04-23-2008, 09:30 PM
jdmvette
Night Owl for life
jdmvette's Avatar
Received 3,247 Likes on 1,668 Posts
elbow grease.
jdmvette is offline
Old 04-23-2008, 09:36 PM
mbroadway
mbroadway's Avatar
Is this black crud oxidation or road tar?
mbroadway is offline
Old 04-23-2008, 09:57 PM
VettRick
VettRick's Avatar
For an everyday wash I use a toilet brush to get at the barrel between the spokes. But once a year you have to take off the wheels, clean them real good, polish as good as they will get, and put on a couple coats of wax or sealer. If tar gets in there and cooks on, it will eventually go through the clear coat and corrode the alluminum in spots.
VettRick is offline
Old 04-23-2008, 10:08 PM
ACR Z06
ACR Z06's Avatar
[QUOTE=VettRick;1565157529]For an everyday wash I use a toilet brush to get at the barrel between the spokes.QUOTE]
Now that is a great idea, i'm heading out to kmart tomorrow for a toliet brush
It's such a PITA to clean the inside of the wheels, i can't count how many times i finished with bloody knuckles.
Patrick
ACR Z06 is offline
Old 04-23-2008, 10:11 PM
10U 99
10U 99's Avatar
steel wool comes in handy.
I'll pass along your compliment
10U 99 is offline
Old 04-24-2008, 12:03 AM
Jacks02
Jacks02's Avatar
Being a long-time British car enthusiast, I use my natural bristle wire wheel brush after spraying on some "Fantastic" household cleaner -- then hose off. It gets to every thing, comes out perfect, no scratches, preserves the factory clear coat, and it's cost-effective. (Abrasives, steel wool, and sand paper not recommended.)
Jacks02 is offline
Old 04-24-2008, 12:31 AM
fnseeker
fnseeker's Avatar
I clean mine twice a year with WD 40. Let it soak on most heavy stuff. Will not hurt the wheel and only a small amount of extra elbow grease is needed.
fnseeker is offline
Old 04-24-2008, 01:48 AM
Jistari
Jistari's Avatar
Anything you hit with something as abrasive as steele wool, will never "stay" clean.
Not sure if your wheels are cleared, or if you already are through the clear coat and the stuff has eaten into the aluminum.
If thats the case, you probably should polish em to as near perfection as you can and then have the barrels recleared at a body shop.
If you are not through the clear on them, try not to use an abrasive. Once you get them clean, wax em (treat clear coated finishes as you would any other painted surface on the car) and they should stay pretty good.
Jistari is offline
To What is best way to clean crud off the inner barrels on aluminum wheels?
Old 04-24-2008, 08:10 AM
10U 99
10U 99's Avatar
0000 wool is so fine it will polish aluminum. we're not talking brillo pad here.
10U 99 is offline
Old 04-24-2008, 09:22 AM
NCSU
NCSU's Avatar
I paint the inner barrels flat black from day 1 and never worry about it at all, lol. The inside of the wheel isn't really a thing of beauty anyways.
NCSU is offline
Old 04-24-2008, 11:03 AM
PaceThis
PaceThis's Avatar
Go to your local auto store and get a rust/paint stripper for your drill. It's a black composite mesh and will have them clean in about 5 minutes per wheel. I've used it on HRE's and it worked great...
PaceThis is offline
Quick Reply: What is best way to clean crud off the inner barrels on aluminum wheels?
