Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-21-2008, 11:33 AM   #1
kluczenk
CF Senior Member
kluczenk's Avatar
Default 2001 Battery Replacement (group number)
Does anyone know the group number for the battery in a 2001 C5? I need to replace the battery but don't have the car or manual local and I'd like to pick up the battery before heading over to the car. Also, how many amps does the stock battery put out?
kluczenk is offline   Reply With Quote
Old 04-21-2008, 11:43 AM   #2
bobby777
CF Senior Member
Get a ac delco 5 year pro series--sealed battery--550 cold cranking--dealer will give you all info-
bobby777 is online now   Reply With Quote
Old 04-21-2008, 12:23 PM   #3
bestvettever
CF Senior Member
bestvettever's Avatar
Default Which battery
Hi, for a replacement battery for your car you can get many different brands with many different part #'s .
If you want a Delco the proper one is either the ACD 75-60 with 680 CCA at about 100.00. Or the pro series # 75 DT 7yr with 700 CCA at about 20.00 more depending on where you buy. The pro series has the best warranty giving 50 months FREE Replacement and the remainder of the 7 yrs pro rata. I believe the other is 18 or 24 mos FREE and 6 yr pro rata. The pro series has vent caps for adding water and the other is sealed. Places like PEP boys sell the ACD 75-60 under their own part # and give a better warranty. The pro series is a great battery, but for the corvette I would prefer the other because it is sealed and cleaner. It is more than adequate and more powerful that the oem in the car originally.
If you chose to go with an OPTIMA as many do , the one that can fit well is the 34/78 Dual Terminal with PUCK ADAPTER, you need the PUCK ADAPTER to make it fit right in the vette. They cost about 170.00 at Advance Auto Parts, other sellers may have different prices.
There are other choices in the 34/78 group that can fit and are less expensive.
The common wisdom when it comes to corvettes is get the one that is sealed and would be cleaner to use. And use a maintainer when the car is not in use.
Also when disconnecting the battery it is wise to disable the radio theft lock before doing so.
Good Luck
bestvettever is offline   Reply With Quote
Old 04-21-2008, 12:52 PM   #4
chuck1026
CF Senior Member
Cruise-In II Veteran
chuck1026's Avatar
The Optima Redtop 75/35 fits perfect in my 2001 C5.
__________________
Ombrophobic 2001 Torch Red Coupe - 6 Speed w/ Z51
Mods:
  • B&M Ripper
  • CCW SP500's w/ engraved C5 logos, 18x9.5", 19x11" w/
  • 245/40/18, 285/35/19
  • Hotchkis sway bars
  • Z06 air box & Ti Exhaust
  • Red calipers w/ C6 Z51 rotors & ceramic pads
  • Lowered
  • "Nasty98" Rocker Savers
  • Elite gas pedal
"Little red Corvette, baby you're much to fast (yes you are)"
chuck1026 is offline   Reply With Quote
Old 04-21-2008, 03:04 PM   #5
Dave68
CF Senior Member
Dave68's Avatar
Here's what I just bought:
Click the image to open in full size.
...best free-replacement (no cost) warranty in the business (50 months) and $99 at Summit Racing.
__________________
2001 Mag-Red Coupe 6-Speed, 1SC, Z51, Born: May 17, 2001, delivered June 7th, 2001
315.9 RWHP 337.7 RWTQ (Dynojet) 6/8/02 (no mods)
328.8 RWHP 352.2 RWTQ (Dynojet) 5/22/04 with Halltech Stinger intake and CAI mod
Quad Round Borla Stingers 9/6/03
2002 Z06 airbox, 2013
Cold-air scoop mod 5/20/04
TPS Z06 shifter (replaced BPP on 12/26/11)
Intake install, oil trap, and CAI mod: http://www.conceptualpolymer.com/corvette_c5_corner.htm
Dave68 is offline   Reply With Quote
Old 04-21-2008, 03:46 PM   #6
Oldvetter
CF Senior Member
Oldvetter's Avatar
If you want an AGM Battery (sealed and won't leak acid), you can get an Optima, Excide Orbital, or Sears Platinum.
Whichever battery you get, use a battery maintainer if it sits for more than 3 days.
Oldvetter is offline   Reply With Quote
Reload this Page 2001 Battery Replacement (group number)
Tags
01, 2001, 75, 78, ac, adapter, battery, corvette, delco, dt, group, professional, puck, replacement, required, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
