Why larger diameter wheels in rear?
Old 04-15-2008, 10:25 AM
Dominic Toretto
Dominic Toretto's Avatar
Default Why larger diameter wheels in rear?
I guess this is just a general automotive question. I have noticed this for years but never bothered asking, but in sports cars such as the Corvette why don't they come standard with the same diameter wheel in the front? I understand the use for wider wheels in the rear for bigger tires for better traction but what's the deal with the smaller diameter wheel in the front? Why not 18s all around?
-Alex
Old 04-15-2008, 10:35 AM
Speeed-Racer
Speeed-Racer's Avatar
St. Jude Donor '12-'13-'14-'15-'16-'17
Rotating mass is the biggest killer of HP. The smaller the diameter, the more the weight is centered with the axle; therefore, the weight rotates less. The lighter the wheel/tire and the smaller the diameter, the better translation to HP. Take a look at a dragster.
Speed
Old 04-15-2008, 11:59 AM
Dominic Toretto
okay so why not then 17s all around?
-Alex
Old 04-15-2008, 12:01 PM
j curtiss
j curtiss's Avatar
Perhaps it was a cosmetic decision.
Old 04-15-2008, 12:07 PM
NAVY08
NAVY08's Avatar
St. Jude Donor '06-'07
cosmetic/ better areodynamics with the nose down
Old 04-15-2008, 12:11 PM
Drewstein
Drewstein's Avatar
Old 04-15-2008, 12:49 PM
Speeed-Racer
Originally Posted by AlexSmith
...for bigger tires for better traction...
-Alex
Also ^
HP/aerodynamics/etc related, it is nearly always a compromise of some sort.
Speed
Old 04-15-2008, 12:57 PM
rcarl
rcarl's Avatar
Speed
I'm by far not an engineer, but out of curiousity wouldn't this only have an effect on the drive wheels??
Old 04-15-2008, 01:11 PM
Speeed-Racer
Originally Posted by rcarl
I'm by far not an engineer, but out of curiosity wouldn't this only have an effect on the drive wheels??
[Not that I am an engineer either, but] The mass on the front still has to be overcome by the HP and it still rotates, therefore not just the rears killing it here.
nice, recent thread on the subject
Look for mqqn at post #9 and AU N GEL at post #14 for a deeper explanation.
Speed
Old 04-15-2008, 01:28 PM
jak112460
jak112460's Avatar
Here's why. If you take a wider wheel in the rear and pair it with a narrower wheel in the front of the same diameter, the front wheel looks like it's larger diameter than the rear. It's an illusion but it does look like the fronts are bigger. I hate Vettes with same diameter wheels all around. In fact my Charger STR8 suffered from the same problem. I used to have a GTO and everyone was doing same diameter wheels front and back but with deep rims on the back. The fronts always looked bigger. I have attached a picture of my GTO two different diameter wheels and they look like they are the same sizes.
Old 04-15-2008, 01:31 PM
IM28702
IM28702's Avatar
I assume, and I wasn't on the design team, that they did that so that they could run a taller tire in the rear and have the same size sidewall.
Old 04-15-2008, 04:02 PM
10U 99
Support Corvetteforum!
10U 99's Avatar
St. Jude Donor '08-'09
read All Corvettes Are Red. Joe Spielman and John Carafo decided the car looked better with larger rear wheels. Spielman was the boss hog developing the C5. what the larger rears lost in cD and weight made up for in aesthetics.
guys, read the book. it's worth the effort....... you will be surprised
Old 04-15-2008, 04:16 PM
B-ras
B-ras's Avatar
Great read
Old 04-15-2008, 05:34 PM
Kamil D.
Kamil D.'s Avatar
Beck looks way bigger
Old 04-15-2008, 05:39 PM
Milan
Milan's Avatar
If you look at the wheels specifically on a C5 it's way obvious the fronts are smaller.
Old 04-15-2008, 08:13 PM
jak112460
jak112460's Avatar
The beck does not look way bigger. Only wider. LOL
To Why larger diameter wheels in rear?
Quick Reply: Why larger diameter wheels in rear?
