[Z06] 03 Z06 Clutch replacement
just got quoted $1800 ( from Tom Jumper - Atlanta )
thats for parts and labor to replace the clutch and flywheel ( it comes together from what they say )
I gotta do it , because it needs a new clutch.
sure does seem expensive though
Kevin
Kevin
That knocks your hat off in the river. I have never repalced one so I am not a good judge but it sure does seem high.
Zosixin wants to know if it is for a stock replacement or for an aftermarket and if the later which brand.
FWIW I looked in the service manual on exactly what this job entails...
it is a pain in the donkey!!! basically everything rear of the engine has to come out of the car (including the rear axle).. I would pay the loot and be done with it..
okay - well I actually feel better now -
I just want a fair deal - and it sounds like this is a fair deal.
I'll be glad when I get the car back - should be later this week.
thanks all , for the replies.
wanna play ? - gotta pay -
Call Ron @ Vengeance Racing. They can put a Textralia clutch in your Z.
VengeanceRacing
241 Castleberry
Industrial Drive,
Suite B
Cumming, Georgia
30040
Phone: 678-513-7105
VengeanceRacing
241 Castleberry
Industrial Drive,
Suite B
Cumming, Georgia
30040
Phone: 678-513-7105
I bet you could probably get a better deal from a Supporting Forum Vendor and Vengeance has a great reputation.
that is a ridicuious price IMO. 10 hours @ $105/hr, are they performing open heart surgery or something? If its not too late shop around for some forum vendors in your area, a common price for clutch R&R is around 4-600 in labor and I'm sure for what they are charging you for an OEM clutch you could save some coin and get an aftermarket unit that will last longer and hold up better to the abuse.
Also, make sure to replace the slave cylinder and pilot bearing while you are in there... hopefully the dealer doesn't try and get you for an arm and a leg on those installs as well. good luck.
too bad you aren't in my area or I'd show you how to do it yourself for half that. its not a hard job at all.
While you are at it, pick up a remote clutch slave bleeder, like the one that L.A.P.D. sells, and have it installed. Makes bleeding the clutch a piece of cake.
