[Z06] X1 cam-only dyno results
01 Z06, only mods are longtubes, deleted cats, corsa catback(probably no power gain there), X1 cam and a tune by Vengeance.
Around 800 ft
Do you have a baseline dyno number. IMHO the only thing dyno numbers are good for is to show how much power/tq was gained from a particular mod, and to see where in the rpm your power lies. I like to know the increase gained.
Unfortunately I don't have a baseline. Only reason I have a sheet at all is because I had the car tuned to make sure it was safe after the cam and longtubes.
I had ECS do my cam, my car had slp longtubes/high flow cats, I had a before and after dyno done, and I got a 70rrwhp increase from the cam on stock heads. I now have American racing headers and high flow cats and in about a month or so I'm getting them to do trick flow heads. Can't wait to see what the increase will be. I have only read great things about Vengance though, I'm sure your cam/tune is optimal.
Im not sure how to feel about your numbers. Good they are, however my car here in Houston dynoed stock at 370 360. untuned with kooks lt, 3" OR and pacecars I gained 8 across the board. same dyno, same conditions. I wonder if 800 ft elevation has anything to do with it.
Who sells the 3" midpipes?
Different cam, lighter valves, better flowing intake and MAF.
On averega '02+ Z06's were pulling 20-30hp more compared to an '01.
I took care of that problem
St. Jude Donor '10
nice numbers i just did a hpe cam kit, longtubes w/cats, pully, and injectors and put 448 weather corrected and about 520 crank hp. it was all done by tommy @angermanagement he def did a awsome job!
