Fuel Pump Replacement
Old 02-16-2008, 11:39 AM
CPapin
CPapin's Avatar
Default Fuel Pump Replacement
Does anyone have the GM Labor Guide that tells the recommended install time for replacing the fuel pumps in both tanks?
2000 A4 Coupe
Thanks!
Old 02-16-2008, 11:49 AM
oaks99
Support Corvetteforum!
oaks99's Avatar
and why do you need this info , i have replaced the one in the drivers side it took about 30 to 45 min.
oak
Old 02-16-2008, 11:54 AM
Corvette-Chris
Corvette-Chris's Avatar
St. Jude Donor '08
oak
I would also only change the drivers side
Old 02-18-2008, 11:43 AM
CPapin
CPapin's Avatar
I was just hoping for the labor guide time. They're usually pretty accurate for the time it takes me to complete the task. thanks for the feedback.
CCP
Old 02-18-2008, 12:05 PM
pec98
pec98's Avatar
Default pump
OK I;am new to this. Why just replace the drivers side?
Old 02-18-2008, 12:10 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,096 Likes on 808 Posts
Because there is only one pump on the drivers side is why
Old 02-18-2008, 01:45 PM
MIKE-C5
MIKE-C5's Avatar
St. Jude Donor '05-'06-'08
Old 02-19-2008, 04:13 PM
bighank
bighank's Avatar
Default Pump on drivers side siphon jet on the other
Originally Posted by MIKE-C5
BIGHANK
Old 02-19-2008, 04:53 PM
Sigforty
Sigforty's Avatar
Cruise-In IX Veteran
It should not take you more than an hour to do just the drivers side. It really depends on how much fuel you have to drain out the tank. The reason you would replace the driver side pump is because it is the pump that sends the fuel to the engine. The passenger side pump is only used to pump fuel from the passenger side tank to the driver side tank.
Old 02-19-2008, 05:56 PM
Russ K
Russ K's Avatar
According to ALLDATA, the warranty time is 7.7 hrs. The retail labor is 10.8 hrs (does not include: drain & refill fuel tank).
Russ Kemp
To Fuel Pump Replacement
Quick Reply: Fuel Pump Replacement
