how can you tell if shocks are bad
I purchased my vett lest your it has a 98.XXX miles on it but I don’t know if the shocks are old or not how can I tell?
I guess you just need to go by handling and mileage. I'm at 136k with what I think are stock shocks (might have been replaced before I bought it, not sure)...I'll be throwing on some C6Z06 shocks this spring since they're cheaper than the stock ones!
Former Vendor
Location: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Im wit billdog
What they said. The bounce test just doesn't work with Vettes....learned that with a C4. Mechanics kept telling me the shocks were OK at 70,xxx but I knew handling had deteriorated. New Bilsteins and it was a different car. I'm gonna replace the '02 factory shocks before the next alignment, somewhere in the 40,xxxxs. Be hard to go wrong at that mileage.
Wounded Warrior Escort '11
Out here in S. Calif, there are a few select areas of the concrete freeways that aren't real flat. If the shocks are bad or dying, the wheels will slap on the concrete as you are driving at normal freeway speeds. Also, as the road dips a bit here and there, check for the car...lets call it sloshing for lack of a better word, sideways a little as it goes through those dips at high speed.
I'm on my 4th set of shocks at 303K miles now. This last set of Bilsteins went on about a year ago.
i have been wondering the same thing about the shocks. i believe mine to be stock and if they haven't been replaced ever, then they are pushing 140k. Im looking into buying another set.
C6 Z06
Are you guys saying that the C6 Z06 shocks are plug and play on a C5? For a daily drive would you recomend them? I am surprised they are less expensive than OEM purchased from other than the dealership, are you sure? I have about 80k and was thinking about putting new one's one. If you feel I am hijacking the thread sorry, don't mean to, and I'll start a new one but I though we would all be interested. Thanks.
Tricky
