DOT 5 brake fluid
Received 8,961 Likes
I believe you are screwed. Once in the system it is extremely difficult to get out.
Got this from an old BMW motorcycle board posting:
http://www.xs11.com/tips/maintenance/maint1.shtml
If silicone is introduced into an older brake system, the silicone will latch unto the sludge generated by gradual component deterioration and create a gelatin like goop which will attract more crud and eventually plug up metering orifices or cause pistons to stick. If you have already changed to DOT 5, don't compound your initial mistake and change back. Silicone is very tenacious stuff and you will never get it all out of your system. Just change the fluid regularly. For those who race using silicone fluid, I recommend that you crack the bleed screws before each racing session to insure that there is no water in the calipers.
Bill
Bill
In my shop we work with brake systems often, I personally would not have the guts to make the change in the first place. But that being said, if you survived it without problems, an old saying comes to mind. If It Ain't Broke Don't F**K With It! You could cause yourself a real pain in your right rear pocket down the road.
I did not chose to go to DOT 5, the shop I use put in the DOT 5 after I asked them to put in a higher temp brake fluid. Doesn't sound like I am in a good spot!
Dot 5 no no
If you do not have problems now I think you are in for a major overhaul of your brake system.
Did he put in DOT 5 or DOT 5.1? DOT 5 is silicone and should not be used in our cars. DOT 5.1 is compatible with DOT 3 and 4. It has a higher wet and dry boiling point and it's all I use in my cars.
I use DOT 5.1 on my 2005 z51 and it works like a charm. DOT 5 though isn't compatible with ABS brake systems and is, as mentioned above, a big NO NO..
Motul600 is excellent brake oil and so is Castrol SRF. Unfortunately, none of em are available where I live so I'm using a DOT 5.1 brake oil made by Carlube (a UK company). harder brake pads and steel lines are also recommended if you want to improve your vehicle's braking power.
