What is this crap on my Brakes
I bought my car a few months ago, and noticed this stuff, but since I just replaced the Wagon Wheels with thin spokes you can see it a lot more. What is this? It is on all 4 brakes.
St. Jude Donor '08
YUP... nothing to worry about mechanically but bush league from a brake installation point of view. Should be easy to clean if you take the pads out of the caliper.
akempucky...gorilla snot.......poor workmanship...I don't think that stuff is necessary on a Corvette...I put the pads on a clean caliper and use a very slight amount of brake grease on the contact points...my $.02
You don't need that much brake quiet on the back of the pads as you can see there isn't that much caliper contact. I greased mine only in the contact areas. You can clean it off if it bugs you that much, or leave it alone... it won't hurt anything.
Location: "This is not a psychotic episode, but a cleansing moment of clarity."
Just wondering... Could that stuff be the end result of painting the hats of the rotors with a shaker can and not caring if the overspray gets on the braking surface of the rotor, figuring it would just burn off?
