Spark plug change not so bad.
I have read the tales of woe and bloody knuckles while changing the spark plugs, and have dreaded the task. So finally, today, after 38k miles and 6 years since new, I changed them and it wasn't bad at all. Here are the 3 things that made the change very easy.
1. I rotated each plug wire a quarter turn at the plug to break the seal. Then, they came off easily.
2. I removed the left side plastic coil cover (aka valve cover). Only after getting my one and only cut.
3. I removed the plumbing between the second and third cylinder on the drivers side, and set it up out of the way. Only 2 bolts here, but it made the rear 2 plugs on the drivers side a breeze.
Total time 1 hour. Not too bad.
1 Post
I'm curious to see if you were missing any of the platnum pucks on the electrodes of the plugs. I changed mine at 50,000 and had several missing. Also the gap was pretty big on most of them if I remember.
Received 19,361 Likes
'20-'21-'22-'23-'24
Congrats on getting them changed. Good tips you mention.
