AIR BAG LETTERS THOUGHTs
If you are in a position where you are deploying a passenger side air bag, you have much bigger problems then the letters coming off and hitting the occupant. If you want to put the letters on and you are not going to do it because you think you might at some point deploy the airbag, time for you to sell your car and start riding a bicycle.
Shrapnel is the term commonly used to describe the metal fragments and debris thrown out by any exploding object, be it a high explosive (HE) filled shell, a homemade bomb wrapped with nails or ball bearings, or a passenger side airbag with metal letters stuck to it . The word shrapnel is derived from the name of Major-General Henry Shrapnel (1761–1842), an English artillery officer, whose experiments—initially conducted in his own time, and at his own expense—culminated in the design and development of a new type of artillery shell.
The term "Shrapnel" originally referred only to the spherical shot or musket ***** dispersed when a shrapnel shell bursts, and this is still the technical meaning of the term, although it is now used to describe all types of high velocity debris thrown out from an explosion, and makes no differentiation to the process which created or produced the debris. (like an airbag going off with metal letters in it?)
I originally got the thin vinyl ones. They stuck well, looked good, easy to install. But my car is a daily driver I don't put up the sun shade as often as I should. After a year, the corners of the thin vinyl stickers were all coming up. I tried to work directly with cyberdinegraphics to get the exact color I wanted, but they were NOT very helpful. Eventually, I bought the cyberdinegraphics 3D raised letters from SouthernCarParts (the kit with the steering wheel and door sill emblems too). I was surprised at how easily the original thin vinyl ones came off. I cleaned the airbag cover 3 or 4 times with isopropyl alcohol. The 3D letters were easy to install, stuck well, and looked 10 times better than the thin ones. A few weeks after install one leg of one letter came back up. A tiny spot of superglue stuck it right back down. No problems since.
DON'T PUT METAL LETTERS ON THE AIRBAG (reference all the shrapnel posts above).!!!!
GO WITH 3D RAISED LETTERS FROM CYBERDINE (not thin ones)!!!!
SCRUB THE AIRBAG COVER WITH ALCOHOL UNTIL YOU ARE 100% ABSOLUTELY POSITIVELY SURE IT'S CLEAN, THEN SCRUB ONCE MORE!!!!
You will love them.
You will love them.
LT
airbag decals
I have the red decals, not the plates. Bad enoughto have one deploy god forbid. Then to have a piece of metal greeting you first................. oh boy !!
I just used the alchohol wipes the vendor sent. Decals don't stick worth crap, but they sure do look good. Tried to get in touch with them about some better adhesive, but haven't heard back from them. I would like to do the steering wheel emblem, but will wait until I find out how to apply them so they will stick.
Cruise-In VII Veteran
I used a paint pen and painted my GF's letters when she owned her C5.
Went a bit farther with mine and had the letters re-positioned (lowered) & airbrushed...
Watch this and decide. If the Corvette cover flips up like this one they probably wouldn't hit you. If the stainless letters did hit you however they would definitely leave a mark.
