Headlight Gear *Bad Surprise* - I feel SO Violated -- WTF?
Located in the sticky note.... but here is direct link...
Brent Franker Link
His site is F-bodies, but the same gear works in the C5.
BTW - The patient has healed and has completely recovered -works just like new
I did fab up a bracket just for sure. It would be hard pressed now to come apart!
Everything is 1/4 inch drive - 10mm socket (with several extensions) and end wrench and about 30 minutes off, 12 hour cure on the glue and 30 min back in. NO problems whatsoever!
Brent Franker Link
Don't know what's in it but it dries and sands just like the material the gear case is made of. I would seriously doubt it coming un-glued.
Good Luck ----->
I went with the Franker solid brass gears since this is the second time I have had to replace the gears. I replaced both with brass gears and the rubber insert and the rubber was destroyed and in little chunks in a year. Mr. Franker and I are doing a little experiment though, he sent me one brass and one anodized aluminum for me to try. The obvious difference is the weight and the color but both fit in there real nice.
