Twilight Sentinel
8th Gear
Twilight Sentinel
My 03 vette is about a month old and I am still waiting for the owner's manual, which was ordered. My question is, can the twilight sentinel be turned off, and if so, how do you do it? Thanks
CHICAGO CREW !
Location: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
if you are in Canada no ... it's a Canadian law for them to be on all the time . maybe you can find a dealer that will turn off the z49 option with a techII . but I do not think you will get a dealer to do it >
8th Gear
thanks for the replys. I thought it was only the daytime running lights that are required in Canada. I tried resetting the twilight sentinel in the options menu, but nothing happens. It appears to be locked.
All you need to do is take out the #44 relay that is located in the fuse box in the passenger footwell. I have had mine out since 2002, everything works fine, you just have to put your headlights on and off manually.
Good Luck
Good Luck
CHICAGO CREW !
the reason I know this is I have a candian 2000 coupe ... my vette tech turned it off but I am in the USA !
That does sound a bit silly you can't turn sentinel off, sentinel has to do with turning on/off the headlights under certain light conditions. The feature is not related to DRLs. Is everyone talking about the same lights, etc.?
Use the link below to download a "pdf" version of the '03 owners manual
https://www.mygmlink.com/pdf/go2cont...03corvette.pdf
Aren't those the two big ones upper left side?
If so remove the two smaller one's next to it, might need needle nose to pull it out (what I used) and then put the smaller two back in.
Received 19,365 Likes
'20-'21-'22-'23-'24
CHICAGO CREW !
if the car is Canadian you can't shut it off believe me . I have one
Location: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
There is another way. Here it is:
http://www.corvettegadgetman.com/
I have a Canadian C5, this is easy to install and works as advertised.
