I guess I let my Corvette brothers down...
I dated a girl with a Miata back in 94 or so. It was a very fun little car to drive. Handled well and seemed fast as it is so low to the ground. I bet with the power you have in that one, it is really a blast.
You didn't let anyone down. Enjoy yourself bro!
1 Post
St. Jude Donor '05
CI VI Veteran
#306 CI DSS Pro Bullet Short Block
*Block balanced and blue-printed
*Heavy Duty H Rods
Stud girdle
#8.7:1 Forged Pistons
Anderson B-31 blower cam
Omega roller rockers (1.6:1 ratio)
Edelbrock Heads/ ported exhaust side( alum.)
Kenne Bell 2.2 blower/13-14 psi boost
Flowzilla Inlet Manifold
36lb Ford Injectors
90mm Throttle Body
80mm Pro-M MAF
Ported GT 40 lower intake
*PMS(Anderson Ford) Piggy Back ECU...fuel..timing..boost controls
Crane HI-6 ignition
*Crane P-92 Coil
Howe Three Row Aluminum Radiator
*Ford Motorsports High Flow Water Pump
#Twin elec cooling fans/ thermostat controlled@185 degrees
Modified K member/using stock oil pan
Koni ( yellow/sport) shocks, with coil overs
Engine oil cooler/thermostat controlled
#Melling High Flow Oil Pump
HD front and rear sway bars (suspension techniques)
JBA Custom 1 5/8in Headers
*Custom 2.5 inch exhaust, with "X" pipe
*Two Magnaflow Resonators
Borla 2.5 in/3 in out stainless mufflers
#Tranny: New T5-Z close ratio 5 speed.
#Hurst Comp-Plus shifter
*Ford Motorsport King Cobra Clutch
Lightweight Flywheel NHRA approved
Rearend: Ford 7.5 center, 3.27:1 gears/limited slip
*Walbro 255lph Fuel Pump
Vortec Fuel Rails
Adjustable Fuel Pressure Regulator
*Optima Red Top Battery
*Hi-Torque Mini Starter
*100 Amp Alternator
Hi Mark,
Hey,a car guy is a car guy,who cares what badge is on it
Good luck with it and have fun,but that sounds like a lot to handle so be safe with it.You just may have enough torque there to turn it inside out!
I thought that engine looked a bit weird. I was wondering how you were getting 400+ HP out of a supercharged Miata engine.
Either way, NICE CAR! Don't listen to the C5 fanatics, I'd much rather drive around in that car.
#36
Lepus-temperamentalus
Last year I sold my supercharged C5 vert. I hated seeing it go but after spending almost 300K on another bodyshop, I needed cash.
I had supercharged the H2 and the gas mileage sucked even worse. I didn't have a problem with that but between driving back and forth between the new and old shop, I was spending 220-240 week in gas. (terrible when you consider that the shops are less than 10 miles apart)
So I traded an alignment rack for a girly car. It was a '95 Miata that soon became painted, lowered, wheels, interior, blah, blah, blah.
I learned soon enough that what it lacked in power, it made up in fun factor... the car is a blast to drive.
Well, about a month ago, I was offered my C5 back at 9K less than I sold it for and it only had 1500 more miles on it.
I hate to say this but I declined. The vette was beautiful and fast but I held off.
Well, this is where I let my brothers down. I bought this last Friday.
Gonna hit the dyno Monday with the new engine but the last engine dyno'd out at 430HP/460TQ at the rear wheels. I'm guessing this one will be a little more, we'll see.
Not bad for a 2200lb car.
So I guess for now, I won't be getting another vette any time soon. Some day, again, definitely but for now, I'll go play with the pocket rocket.
#37
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Mark its a fun car still. No weight and lots of power, its all about that
I want to say "I would race you" but since you have my parts in your shop being painted, I wont say that.
Have fun bro and be safe!
